Power FC PFC pinball, tilt it and it dies, WHY?
Old May 15, 2002 | 11:45 PM
SpeedracerRX7's Avatar
Question PFC pinball, tilt it and it dies, WHY?
I bought my PFC from SR Motorsports in November of last year. My mechanic when changing my motor removed it and noticed a wierd phenomenon when putting it back in. Whenever I unvelcroed the computer the computer and suabsequently the car will not work. As long as it is in there standing completely level the car will run. Well lately I have parked on some hills and when I went to restart the car it just wouldn't. I thought it was flooded or something so I removed the plugs and ECI relay cranked it over and attempted to restart it and it still wouldn't. It wasn't until I tried my stock ECU back in the car from and it started right up. When I got it on a level surface again I installed the PFC and it again fired right up. I tested it by letting the car idle and tilting the ECU. It immediately shuts the car off.
Has anyone else experienced anything even remotely similar? I called SR and they said that I could send it back to them and they could send it back to Japan but that is going to take forever. In the mean time I won't be able to drive my car because I won't have an ECU. My mechanic, Brian at Rotorsports, said that I could offer them my credit card number and SR could lend me an ECU until this one is repaired. I can't afford another PFC and I guess my car is out of commission until it is repaired or replaced. What are some alternatives? Any suggestions? Any help is appreciated.
Old May 16, 2002 | 05:18 AM
Dragon's Avatar
20B N/A Wide Body FC3S
Check your wiring harness, I had a pin that pulled out of the harness connector before. Somtimes it made connection and if I moved the computer around it would lose connection...
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Prediict
32
Nov 18, 2015 08:41 AM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
