Miata rims on a 1st gen??
Old May 15, 2002 | 09:11 PM
trankilo's Avatar
Newbie
Question Miata rims on a 1st gen??
I want to kno if the rims from a 2002 miata se have the same bolt pattern as a 1st gen. i have a 84 GS.
Old May 15, 2002 | 09:34 PM
eddierotary's Avatar
back with rotaries
no. 2002 miata have 5 bolt and rx7 gs,gsl have 4 and early miata either. gs,gsl have 110x4 and miatahave 100x4.
Old May 15, 2002 | 11:29 PM
Project84's Avatar
Open up! Search Warrant!
I was told that a 94 through 97 Miata rear end (everthing on the rear end, break rotors, axles and all) can be put on a first gen. If you can find a wrecked Miata, this is a good way to get disc breaks in the rear, as well as a strong limited slip rear differential.
Old May 15, 2002 | 11:54 PM
Max7's Avatar
Admitted Sevenaholic
Miata's have IRS, that won't swap, just the gears swap, and only certain LE models.
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
