exhaust setup help
Old May 15, 2002 | 08:56 PM
anthony77's Avatar
exhaust setup help
with this exhaust setup, would i need any additional upgrades, like a pmc or boost controller, to prevent boost spikes, turbo damage and or engine damage.
3" ss downpipe
high flow cat
racing beat dual tip
stock intake
appreciate it guys
Old May 15, 2002 | 08:57 PM
Import Convert's Avatar
Stock ecu would be fine with that
Old May 16, 2002 | 02:48 AM
rynberg's Avatar
Not without controlling the boost it won't.
With a downpipe, hi-flow, and cat-back, you will probably be boosting atleast 12 psi, though this varies from car to car. The stock ecu cuts off fuel at 10.7 psi above 6000 rpm or so (the chart is on scuderiaciriani.com). I would never run 3 mods, especially a hi-flow cat, without controlling boost or with an aftermarket ecu.
Old May 16, 2002 | 10:27 AM
jmo87's Avatar
yeah, i think you just need a boost controller.
Old May 16, 2002 | 10:34 AM
Mahjik's Avatar
Mr. Links
If you don't have a boost gauge installed, do that first.
As stated earlier, every car seems to react differrently to modding... I didn't see anything above 10 until after I added my intake and ECU.
It's possible to spike with that type of setup, however I doubt that will happen. To be on the safe side, make sure you have a boost gauge. If you see spikes over 10, then you can think about getting a boost controller.
Skeese
65
Mar 28, 2017 03:30 PM
82streetracer
Aug 23, 2015 09:28 AM
