Installed MSD 6A, now breaking up after 5K
Old Nov 8, 2008 | 05:10 PM
bob13bt's Avatar
Fixed the wheelhop
I never had any ignition problems before, I got the MSD to see if it would help at all. Now it breaks up at about 5K, and is running like **** under WOT. Cruising is fine. I checked the spark, looks good, I ran the ground to the chassis, then added one to the rotor housing which didnt help. Im about to say **** it and take it out, like I said it ran fine before. Just wondering if anyone had a similar problem with an MSD 6A.
Old Nov 8, 2008 | 07:58 PM
jantore's Avatar
Ive never liked MSD with rotary. Ive always had problems with them. But they also need to be setup correctly as well. And u need to bypas the stock igniter if i remember correctly. Long time since i wierd up with a MSD and otherwise stock ignition system. Ive been on CDI for the last 4 years now. And will never go back.
JT
Old Nov 8, 2008 | 09:20 PM
bob13bt's Avatar
Fixed the wheelhop
I have...
Microtech LT8S
stock CAS
NGK BUR9EQP leading
NGK BUR9EQ trailing
factory NGK wires
stock FC Mazda leading and trailing coils
60-1 @ 14-15 psi
again, it runs fine idling or crusing, just breaks up, pulls pathetic, power drops off big time after 5K
So is the MSD 6A designed to work with the Blaster coils, and incompatible with the stock FC coils? I found a wiring diagram from MSD for the Mazda rotary and the picture shows Blasters hooked up....hmmm.
Old Nov 9, 2008 | 09:56 AM
jantore's Avatar
I have...
Microtech LT8S
stock CAS
NGK BUR9EQP leading
NGK BUR9EQ trailing
factory NGK wires
60-1 @ 14-15 psi
Ok have u bypassed the stock igniter on the coils? And have u sett the ignition output correct in the microtech towards the MSD, they need a diffrent setup then the stock igniter i belive. Im not 100% sure, someone with more knowledge then me on MSD should answer this.
JT
Old Nov 26, 2008 | 06:36 PM
ohayou88's Avatar
I have a 6a box on my FC as well. I just followed the instructions on fc3spro and mines works just fine. You sure its not some other issue
Old Dec 3, 2008 | 07:26 PM
Hyper4mance2k's Avatar
The Shadetree Project
http://fc3spro.com/TECH/HOWTO/CDI/cdi.html
do it this way or you'll have problems. MSD's are known for pointing out bad ignition components. You might've thought your plugs and wires were in good shape, that is until the MSD let you know otherwise. lol...
Old Jan 20, 2009 | 02:56 PM
SmokeScream's Avatar
do you set msd box for 4cyl?
s2kguy17
Rotary Drag Racing
Sep 15, 2015 03:05 PM
ncds_fc
Aug 15, 2015 10:06 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
