Power FC Best Injector Combo?
Old Nov 4, 2008 | 11:39 AM
superjet3's Avatar
Hello, I recently purchased a Power FC and Datalogit. I am currently rebuilding my motor and I want to upgrade the injectors. I noticed a lot of people running the stock 550's along with 1300cc secondary’s. I am planning on sticking with the stock twins and to keep the HP numbers around 350. However, I would like some wiggle room if I decide to shoot for more in the future. I don’t want to go to big for tuning / drivability reasons. Any ideas on what would be a good place to start? Also, is it recommended to have the 850's modded to 1300's?
Old Nov 4, 2008 | 04:05 PM
cewrx7r1's Avatar
Eye In The Sky
550 primaries with the 850 secondaries bored out to 1200 with an upgraded fuel pump with the FP wiring improved is your best choice.
850 --> 1300 have had high failure rates.
Old Nov 4, 2008 | 06:05 PM
Dudemaaanownsanrx7's Avatar
wannaspeed.com
850/850 with rewired pump would also get you enough fuel for your HP goals. It would be a cheaper alternative, (I have some forsale) but you might have some trouble getting a lean idle. Some people have no problems with this and others have a harder time getting a lean idle.
Old Nov 6, 2008 | 06:11 AM
superjet3's Avatar
Who is the best company to hvae the mod done by? I am having a hard time finding any injectors over 850cc which are side feed.
Old Nov 6, 2008 | 06:58 PM
twisted7's Avatar
Jake
I really havent had any driveability problems with my primary milled rail with 850 and 1680 secondaries.
I just went big because i knew down the line i would want the extra fuel.
If you just want around 350 than stick with an upgraded pump rewired for more voltage, and like chuck said 550's with 850's bored out to 1200. You would have a nice smooth idle and still get some good mpg.
at 334hp with 850/1680 i was getting 22mpg
Old Nov 6, 2008 | 08:53 PM
wannaspeed.com
yeah i think the 850 primaries mainly only have an issue at idle where the MS on time is the least
Old Nov 6, 2008 | 09:05 PM
Actually, my idle is good ,but I have driveablity issues, just in vacuum, while light throttle driving. I'm running 4 x 850cc
Old Nov 6, 2008 | 09:07 PM
Injector upgrade
RC Engineering
Old Nov 12, 2008 | 09:18 PM
mono4lamar's Avatar
In the burnout box...
Go with 850's all around you have the capability to make 410whp at 80% duty cycle. Bored injectors have an actual failure rate. Case closed...
Old Nov 14, 2008 | 01:54 AM
gracer7-rx7's Avatar
needs more track time
+1
except I run 1300cc secondaries for 5 years or so now. Street port, 99 twins running sequentially and all supporting mods resulted in 350 rwhp at 15 PSI.
great idle, great part throttle response, good low RPM response for good street manners. Trying to fit 850s into a primary rail 'works' but its kind of a goofy setup as they never fit 100%. Yeah you can mill the primary rails to allow you to install them but the rest of the injector just doesn't sit in there perfectly like the 550s do.
Turblown
Mar 21, 2018 11:19 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
connerfd3s
Sep 19, 2015 05:58 PM
