Megasquirt car wont start
Old Nov 2, 2008 | 01:00 AM
lonewolfrx's Avatar
car wont start
I have an zeal ms1 v3.0. pnp. I pluged it in and its just cranking. The leds light up. Not sure what could be the problem. Unless the map on it wont start a bp. I just wanted to move the car from the shop to my house.
Old Nov 2, 2008 | 10:16 AM
Aaron Cake's Avatar
Engine, Not Motor
There's likely not enough fuel to start a bridge on the stock map.
A bridgeport needs a LOT more fuel.
To give you an idea, my half bridge idles around 13.5:1 at 2.47ms on 720CC injectors. I just finished tuning a stock S4 TII that idles at around 13.5:1 on the 550CC primaries at 1.5ms.
Old Nov 2, 2008 | 11:41 AM
lonewolfrx's Avatar
i see.. would i have to edit the cranking settings?
Old Nov 2, 2008 | 11:47 PM
Vierte's Avatar
i would first set your engine constants as you probably have larger injectors then what the stock map uses. then calibrate tps. next verify that you have spark, and that the timing is accurate. then you can play with cranking pulse widths to get it to fire up.
i probably missed something important so i would find the megamanual that instructs you on first startup procedures.
good luck!
Old Nov 3, 2008 | 09:21 AM
Aaron Cake's Avatar
Engine, Not Motor
What he said. But most certainly you would need to edit the cranking settings and of course, retune the entire VE table.
Old Nov 3, 2008 | 05:33 PM
lonewolfrx's Avatar
anyone have a base map i can edit?
Old Nov 4, 2008 | 08:46 AM
Aaron Cake's Avatar
Engine, Not Motor
There is already a base map on the ECU.
Old Nov 4, 2008 | 06:23 PM
lonewolfrx's Avatar
i would dl it from the ecu but right now i dont have the cable. my friend borrowed it. thats y im askin if anyone has the base map so i can just work on that then just upload when i get the cable back
Old Nov 5, 2008 | 09:14 AM
Aaron Cake's Avatar
Engine, Not Motor
Just go to a computer store and buy a $5 cable. Then you can edit the ECU settings at your convenience.
Kyo
Apr 13, 2019 09:24 AM
gtcd
30
Aug 19, 2015 02:44 AM
torky007
Aug 17, 2015 05:14 PM
ashleymiche
Aug 14, 2015 12:59 PM
