water temp problems! please help
Old May 14, 2002 | 08:45 PM
According to my pfc commander, when the 13b is warmed up, it reads anywhere between 35-50 degrees celcius. This is way to low! Shouldn't it be running from 90-100 deg? Anyway, the problem is that the car won't reach full boost till after about 50 degrees, which I hardly ever reach. Has anyone ever heard about this one? Could it be a bad sensor or connection? Can it be re- calibrated or something? Please here my cries for help. An FD without boost is like an athlete without steroids. Please help.
thanks in advance.
Old May 14, 2002 | 09:35 PM
user 84205's Avatar
actually if your running Celcuis. it should be about
85-100 depending on driving and weather...
way to low temp... I think your PFC reading temps are wrong... You can adjust actual temps and reading temps...
Old May 14, 2002 | 09:36 PM
boostedyellow7's Avatar
how did you get tour pfc to tell you the temp?
Old May 14, 2002 | 09:39 PM
user 84205's Avatar
it can tell you everything thats why they are soooo nice... You can pick how many and what you want it to display. 1-8 things at once.. I have my water, boost up..Just the 2. What is shown on your display right now?
Old May 16, 2002 | 10:54 PM
right now I'm displaying 4:boost, wtr temp, air temp, and inj. duty. Did I here you right???? Is there a way to adjust the reading off the pfc? The water temp on the stock reading is normal. right in the middle like usual, but the pfc keeps reading 30-40celcius. watahek. If you can, pleeeeeeeeaaaaaaaase tell me how. This would just make my day. thanks
Old May 16, 2002 | 11:02 PM
user 84205's Avatar
just change one of your settings to knock. Press back, then select airtemp or something and change it to knock, scroll it with up and down to get to it, the right to actually select it. then put it on knock and press next again then it should show right up...
Old May 16, 2002 | 11:04 PM
user 84205's Avatar
for water temp, go to the page for water temp. Its in your settings area. Then tell me the number your see.
it should be like
1.00 1.00
1.04 and I cant remember the rest, just post them, then I will tell you mine.. Hopefully that will help you out.
There should be a display and an actual temp...
Old May 16, 2002 | 11:34 PM
thanks for your help man. I appreciate it.
it reads.....80 - 1.00 1.00
50 - 1.07 1.01
30 - 1.26 1.21
10 - 1.60 1.50
-10 - 2.01 1.87
-30 - 2.81 2.57
Old May 17, 2002 | 01:42 AM
user 84205's Avatar
Right now I cant get to my car, its flooding a little right now. So did you do a sensor check before too. I cant get the numbers off my FC right now. I will have to get back to you when the rain stops....
Old May 19, 2002 | 12:04 AM
I haven't done any sensor checks yet. What actually am I checking? voltages ? let me know.thanks.
Old May 19, 2002 | 02:15 AM
Tom93R1's Avatar
gross polluter
What exactly do the number in that table mean?
Old May 20, 2002 | 09:46 PM
Old May 24, 2002 | 05:13 AM
smacho7's Avatar
I may have resolved a simular issue on mine ... however, I did it in the ECU - Power FC form
the thread is named -36c temp ...
:~) Steve
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
mulcryant
Sep 9, 2015 05:24 PM
