new wheels and tires.
Old Oct 30, 2008 | 10:40 PM
silver80sa22c's Avatar
ok i got the 205 - 50- 15 enkei wheels put on.. the rub on the plastic in the wheel well which i can take out no big deal or cut or whatever. im taking my 85 to a place called Turn in Concepts on portunion rd in fairfield. THey said they could flare my fenders.. do you think its possible to do the whole wheel well not just the top??? i need some input on this nowww
Old Oct 30, 2008 | 10:47 PM
Rogue_Wulff's Avatar
Too old to act my age
What is the offset on those wheels? It should be listed somewhere on the wheel, near the lugs. Likely as "ET 20" "ET 15" "ET 0" (I'm betting on the last one).....
Old Oct 30, 2008 | 10:49 PM
im pretty sure its zero bc with the tire off of the rim if you look at the bolt holes they line up with the center of the rim.. like the width of the rim the bolt holes are dead center
FB_Frank85
Sep 6, 2015 11:29 AM
