Purchasing 13b used engine
Old Oct 30, 2008 | 01:30 AM
If someone were to purchase a used motor and did a compression test and a coolant system pressure test, would this be satisfactory to determine if the car is going to run for a few years?
Old Oct 30, 2008 | 03:18 AM
thewird's Avatar
If your going to spend your money, do it right. By the time you get it installed and working right you'll have spent close to the same money and the end result won't be the same. My opinion anyway...
thewird
Old Oct 30, 2008 | 03:22 AM
Ottoman's Avatar
always modding
unless ur current motor is trashed.. and doesn't have good parts to re-use..
ur better off having ur current motor overhauled..
Old Oct 30, 2008 | 03:35 PM
96fd3s's Avatar
nothing is certian with rotary engines.
just because it passed a compression and coolant test, that has no reflection on how long the engine will last. the engine could last 5km or 100k km it all depends on the conditions its exposed to.
cdn
14
Sep 10, 2015 06:23 AM
ncds_fc
Aug 15, 2015 10:06 AM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
