need advice troubleshooting my tach, no reading
Old Oct 28, 2008 | 09:25 PM
notveryhappyjack's Avatar
1 bar boost
I must have shorted my tach out because it has stopped working at the moment. I did unplug the battery and since reconnecting it the tach stopped reading rpm. On a 13b what on the engine tells the tach the reading, this will help me with where to start troubleshooting. I would appreciate idea's on what tools I need and where to start searching for a short or blown fuse.
Aaron
Old Oct 28, 2008 | 10:05 PM
fc3s91's Avatar
R.I.P Mark( Icemark )
Check your trailing coil. That is were you get your tach signal.
Thanks Robert
Old Oct 28, 2008 | 10:57 PM
chrisw80's Avatar
Arrow
ya do a search for it alota people have had that problem, check your wires on the trailing coil. i have had that before.
Old Oct 28, 2008 | 11:10 PM
woundup7's Avatar
The Outsider
Aaron, the tach is fired off of the msd box on the side opposite of the main wires there is a single wire with a spade connector that plugs into the msd box. It might have come dissconnected or the fuse that power the msd popped or became lose on the wiring side. The fuse is one of the main fuses in the S-4 fuse block bolted to the driver's side strut tower. iirc it is a 30 amp one. Follow the main power wire from the msd box "red one" back to the fuses and trace what fuse it plugs into. Thats probably the prolblem
On a side note that msd box has been rebuilt by msd about 2 years ago, it may have crapped out again. If you have any questions pm me, and I will try to help. Busy swapping in a 5 speed on the battle wagon, but always have time for one of my former cars.
Old Oct 29, 2008 | 01:10 AM
1 bar boost
thanks for your help Chris, I was sure that I needed your expertise on the issue, car seems to be firering just fine so I doubt the 6al box is fried. But I will check out that out tommorow.
Good luck swapping a stick in the brick.
We should have another highway pull, this time with the same number of gears
Old Nov 3, 2008 | 08:50 AM
z-beater's Avatar
REW'd FB
HAHAHA, that is awesome.
rgordon1979
40
Mar 15, 2022 12:04 PM
Bauer778
Nov 4, 2015 04:42 PM
risingsunroof82
Sep 7, 2015 01:11 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
