Series8 vs series6 engine?
Old Oct 26, 2008 | 04:40 PM
ImamurA's Avatar
hi...are there any differences between the series8 engines and the series6 engines?...do they have different port sizings?...im talking about the engines alone...thanks
Old Oct 27, 2008 | 02:28 AM
Ottoman's Avatar
always modding
core is the same.. turbo's and and electronics are the major differences...
Old Oct 27, 2008 | 04:11 AM
evilg's Avatar
Where's this bolt go?!!!?
I read somewhere that there is a size difference in the oil injection ports.... something to do with reducing the amount of oil needing to be injected, whilst making that amount distribute more evenly.... guess that means that rotor housings are different.
Old Oct 27, 2008 | 04:12 PM
billyboy's Avatar
Oil injectors were reduced in size and grommets inserted into the ports to effect that change ^^^....along with an alteration of the pump. The actual brass injector opening into the housing looks like it is press in rather than screw in, which appears to be the only physical change in that area.
Going off part numbers, the housings went N3A1 > N3G1 into the early production and then superceded by N3Y2.....so a whole host of minor changes in production, some you'd be hard pressed to notice, is my guess.
Old Apr 4, 2010 | 06:53 PM
ImamurA's Avatar
sorry to bump an old thread....but i want to rebuild my motor in the near future and i want to use brand new rotor housings...i can get series6 housings easily but would this be able to work with the other series8 parts?...would the slight alterations in the hosings mean that i would have to change other parts to make them work?
Microtech
30
Apr 23, 2016 06:37 PM
Wicked93gs
Aug 23, 2015 10:14 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
