Haltech Wire Harness Connector Reassembly?
Old Oct 25, 2008 | 04:14 PM
fritts's Avatar
Mad Man
Anyone have any tips on how to reassemble the harness connector after you add or modify pins. I'm having a heck a of a time getting the pins to align and keeping the white pin lock in place.
Old Oct 26, 2008 | 11:38 AM
fritts's Avatar
Mad Man
Ok well my white locking clip came out with the pins when I took the connector apart. I figured the clip needed to be in place on the pins before inserting it into the body of the connector. That is wrong though. The locking clip is put into the pin body and then is pushed up or down depending on which one locks the pins. In the unlocked pin position insert the pins and seal. You main need a thin wire pushed into the body holes to help the pins align with their holes for the white locking clip and body. Then snap the connector together. The lock clip and seal can then be clipped to the main body of the connector.
Old Oct 26, 2008 | 09:14 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
Hey Fritts, you actually dont have to take the connector appart on E8/E11 to pull or push pins in and out of it. Just press the large white guide down, and the 2 small ones on the other side will pop out about 1/16 of an inch, and you can just pull each wire out, and after inserting it you just push down on the 2 small ones.
PRESS
PULL
CRIMP
INSERT
PRESS
These steps are for adding pins to a location where there werent any, like on a PnP or adding the Aux. Out 2 on an E8 harness which isnt on there from the factory. But the principal is the same, there's no need to take the entire connector apart, the wires just slip in and out by just pressing on the white guides.
Hope that helps.
Old Oct 26, 2008 | 09:49 PM
crispeed's Avatar
'Tuna'
I remember the first time I did that. It took me like two days to figure it out and that's after I destroyed the plug!
Seriously I don't think I even remember how to pull the entire plug apart. I have a couple of new ones sitting around. When I'm bored I'll play with them.
Old Oct 26, 2008 | 11:48 PM
EFI Tech Wannabe
Hehe, same here, ruined one plug and all 34 pins after i tried to put one together, hat's off to the people who put harnesses together down in Oz.
Old Feb 5, 2011 | 12:34 AM
13B-RX3's Avatar
7s before paint!!!
Please restore those pics Claudio!!!! I want to make sure i don't mess anything up!!!
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
