Not getting full boost
Old Oct 22, 2008 | 05:59 PM
M14socom's Avatar
The problem started when I got back from vacation and somehow my steel braided fuel line was leaking? Anyhow I pulled the uim off and replaced the fuel line, but when I got it all back together I noticed the charge relief solenoid had a broken nipple on the top, so I put a tad bit of superglue on it to hold it in place and jb welded it on. There is a possibility that I superglued it shut? What would this cause the car to do? So now the car only pulls like 15psi of vacuum instead of 18 and only spools to 4-5psi on the primary only. It also makes a strange "hoooo" of a noise, every now and then. Would all this happen if the charge relief solenoid wasn't working? Should I just go single?
Old Oct 23, 2008 | 01:22 AM
zack4173's Avatar
I would just replace the solenoid first the are only like $15 its worth checkin out
Old Oct 23, 2008 | 04:46 PM
M14socom's Avatar
Ok, where can a get a charge relief solenoid for 15 bucks?
Old Oct 23, 2008 | 04:52 PM
Sideo's Avatar
my charge relive solenoid broke the nipple on top, i glued it and im also only getting 5 psi of boost
Old Oct 23, 2008 | 04:58 PM
tt7hvn's Avatar
^ i'd guess it's reasonable to assume that gluing it didn't work
Old Oct 23, 2008 | 05:00 PM
tt7hvn's Avatar
i'd look into my solenoid relocation thread while you're at it, just a thought
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/finished-solenoid-relocation-795827/
Old Oct 23, 2008 | 05:25 PM
M14socom's Avatar
So If you have the exact same problem it must be the solenoid... so Where can I get a new one, without paying $60?
Old Oct 23, 2008 | 05:29 PM
tt7hvn's Avatar
you might be able to find one on the for sale section
notice: all the solenoids are exactly the same BTW, just relocate the breathers accordingly to make it whatever, ie; charge relief, charge control, turbo control, etc
you could elminate your double throttle (or something else) and you'll have an extra solenoid
the wategate control, turbo precontrol and turbo control 2 are different solenoids though, the rest of them are exactly the same.
Skeese
65
Mar 28, 2017 03:30 PM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
CaptainKRM
15
Aug 29, 2015 01:33 PM
Turblown
Aug 14, 2015 04:48 PM
