Clutch types
Old Oct 21, 2008 | 08:11 PM
FcJohnny's Avatar
Clutch types
I'm about to purchase a new clutch this weekend off of ebay and I was searching ebay and I see that there clutches for 89-91 gxl and gtu and 86-91 convertible. Well I have a 91 na Coupe sooo does it mater if I buy the one that says gxl and gtu or the convertible clutch?
Old Oct 21, 2008 | 11:43 PM
iani1.1's Avatar
DILLIGAF
i wouldn't trust an ebay clutch. get an exedy oem or a stage 1 if its a daily driver. so far im pleased with my stage 1 exedy. theyre not too expensive either
http://www.exedyusa.com/race/10806
http://www.exedyusa.com/race/10037
Old Oct 22, 2008 | 12:07 AM
Boosted11's Avatar
Pistons are gay
Why does everyone look at ebay first before searching google for aftermarket parts? ...... I would go with ACT, centerforce, or like the above posted exedy. While your in there I would think about getting a lightweight flywheel.
http://www.advancedclutch.com/produc...d_id=2880#2880
Old Oct 22, 2008 | 01:21 AM
RotaryRocket88's Avatar
Top Down, Boost Up
To answer your question, all NA clutches are the same. I'd also suggest going with something better than a ebay clutch. There are some decent ones, but it's always going to be risky buying cheap parts that rotate at 7,000+ RPM.
Old Oct 22, 2008 | 01:35 AM
na5's Avatar
na5
anyone seen my head
check out racingbeat.com if you want a good clutch and not too expensive
Old Oct 23, 2008 | 11:51 AM
InNeedOfBoost's Avatar
Yes, I need boost
not trying to thread jack, but im in the same boat (just not with ebay, only in getting a new clutch).
whats your opinion on a centerforce I from mazdatrix?
Old Oct 23, 2008 | 12:02 PM
RETed's Avatar
The only differences is thickness of the clutch disc - I think the S5 is thicker.
This is according to Mazda OEM spec, so I think the aftermarket clutch guys sometimes follow this.
The clutch thickness isn't that big a deal, since the clutch pressure plate is self adjusting.
This is why most aftermarket clutches are listed as the same part number for ALL non-turbo FC applications.
As for the Centerforce 1...
It's an OEM replacement.
It's not meant for higher power levels than stock, do if this clutch is going on a stock car, you should be fine.
If you car is modified, there are a lot better options out there than a Centerforce 1.
-Ted
sinclair7seven
11
Sep 11, 2015 10:15 AM
risingsunroof82
Sep 9, 2015 08:06 PM
