Lower boost at 4500RPM
Old Oct 21, 2008 | 02:04 PM
drew32's Avatar
So lately when i've been driving my car and boost i hold strong at 10psi on the first turbo but when it switches around 4200RPM i feel a drop and my boost controller reads only 5psi. Sometimes, and its not often i do still get full boost on the second turbo, usually in gears 3rd and up.
I did some searching on the forums and from what i found its one of three solenoids:
Turbo Precontrol
Charge Control
Charge Relief
I'm going to go digging into the rats nest soon with a mitivac and test those solenoids see if any are bad, but first I wanted to see if anyone else had any other ideas on what it could be or other things i should check while i'm in there.
Though it prolly doesn't matter, i'll list what i have done to the car:
Intake
Full 3 inch exhaust, no cats
Power FC (newer base map)
Greddy Profec B boost controller
Old Oct 21, 2008 | 03:32 PM
thewird's Avatar
You sure that's just not the secondary turbo transition? lol
thewird
Old Oct 21, 2008 | 04:10 PM
drew32's Avatar
No it holds 5 psi up to redline i mean.
Old Oct 24, 2008 | 09:26 AM
drew32's Avatar
No one has any other possibilties?
Old Oct 24, 2008 | 09:43 AM
zenofspeed's Avatar
thewird
Even if it did come back up, the transition (if working properly) should only drop 2-3psi and be VERY fast.
Vacuum lines are of course a possibility. It was annoying things like this constantly happening that finally drove me to single.
Old Oct 24, 2008 | 12:02 PM
drew32's Avatar
Hopefully it is just a popped off vacuum line. That would be great haha.
cristoDathird
28
May 30, 2019 08:47 PM
C. Ludwig
Jan 30, 2019 06:31 AM
CaptainKRM
15
Aug 29, 2015 01:33 PM
