coolant system test kits ?
Old Oct 20, 2008 | 12:47 PM
M104-AMG's Avatar
Anyone have any direct experience with either the Pineapple Racing, or the Atkins Rotary coolant test kits ?
Specifically, which one is best for testing with a pulled engine or with the engine already in the car.
Thanks,
:-) neil
http://www.atkinsrotary.com/store/pr...cat=568&page=1
http://www.pineappleracing.com/index...ROD&ProdID=142
Attached Thumbnails coolant system test kits ?-coolantsystemtestkitthumb.jpg   coolant system test kits ?-cspt-5a.jpg
Old Oct 20, 2008 | 02:16 PM
gracer7-rx7's Avatar
needs more track time
Both of those are used to test an engine out of the car. Great way to make sure you didn't make a mistake assembling an engine. Every builder should have one and use it!
A regular coolant system pressure tester will test the entire coolant system with the engine and cooling system all connected. This is a great way to make sure your entire cooling system is working properly and you aren't getting leaks from hoses or weak hose clamps or a leaky radiator etc.
Th0m4s
Feb 26, 2019 02:04 AM
efini7
Test Area 51
Sep 4, 2015 02:59 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
