compression question
Old May 13, 2002 | 10:24 PM
violator's Avatar
i know peeps saying 6.0 is the lowest before a engine rebuild. but i got some bunk compression numbers. he said some **** like 90 psi or some crap like that. whats that equivenlent too? 7's? dont know hehe
thanks in advance
Old May 13, 2002 | 10:50 PM
Rx-7$4$me's Avatar
A new good condition engine should be around 100 psi... so yours is pretty damn good
Old May 13, 2002 | 11:18 PM
BrianHeston's Avatar
Beware Of Squirrely Wrath
curiousity...
What's a good number for a stock '82?
With a somewhat messed up gauge(about +25 from 0) I was getting a reading front & rear of 149. I figure if the gauge was still working correctly and just had a bad 0 that means I'm getting about 124...
Just curious,
BrianHeston
Old May 13, 2002 | 11:31 PM
rynberg's Avatar
Actually, the MINIMUM compression for an FD is 100 psi. This is supposed to be measured at 250 rpm at 0 elevation. There are correction factors for different cranking speeds and elevations. Assuming the rpm and elevation are correct, 90 is a bit low but you should have six numbers. If they are all close to 90, I wouldn't worry about it. Your cooling seals will likely go out first.
_Tones_
May 25, 2021 05:37 AM
ZacMan
Sep 19, 2015 09:20 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
Nosferatu
Sep 5, 2015 02:13 PM
