gauge cluster electrical problem.
Old Oct 19, 2008 | 10:38 PM
cambam3486's Avatar
i work for goodyear
so heres the deal. there is a two pin plug from my ignition that every time i turn the car off i have to reach underneath and unplug for my gauges and idiot cluster to turn off. been like that for as long as ive had the car. Any ideas why it does this and how i can fix it or find the short somewhere.
Thanks for any help.
Old Oct 19, 2008 | 11:06 PM
HAILERS's Avatar
HAILERS
Does this plug have one BLACK/WHITE wire and one pure BLACK wire?
I'm talking the color of the wires in the chassis front HARNESS, NOT the igniton switch pigtail wires.
IF this is the case, then the igniton switch itself is bad internally. What is happening, is the switch itself even when off, is connecting the two wires I just mentioned above.
The BLACK is from the battery and has 12vdc all the time. You turn the ignition switch to ON or START, and the switch makes a circuit b/t the black and black/white wires. That act sends batt voltage to the row of fuses labled IG1, in the interior fuse box. That row of fuses now powers the items you listed.
So it has to be a contact inside the igniton switch that is *MADE* all the time. For unknown reasons.
The ignition switch is not that difficult to remove. It's held in with one screw. You do not have to replace the key cylinder etc. Just undo that one screw on the left side of the key cylinder and unplug the wire connectors. Now cost is another thing. I know not what they cost.
Old Oct 20, 2008 | 12:20 AM
cambam3486's Avatar
i work for goodyear
that makes alot of sense about the switch because also when i turn the key all the way to start it kills the power to everything so i have to bring it back to a sweet spot to get the car to start. well guess i better start looking for a new ignition luckily my buddy just picked up a parts car so hopefully i can fix this tomorrow. Thanks man check one problem off the list.
Old Oct 20, 2008 | 08:36 PM
cambam3486's Avatar
i work for goodyear
new igniton still not fixed
well i put in a new ignition switch and my car starts normally and easier but the gauges still stay on without a key. and the plug has a yellow wire and a black wire with a yellow stripe from the front harness that plugs into plug with a blue wire red stripe and green wire yellow stripe. And it was linked to the brake pedal as well i belive. i have no idea.
Old Oct 20, 2008 | 08:50 PM
87 t-66's Avatar
not a drifter
i have a couple gauge cluster harnesses if you want to go that route...PM me.
Old Oct 20, 2008 | 09:02 PM
cambam3486's Avatar
i work for goodyear
well its for an 87 na but do you think that would fix the problem
Old Oct 20, 2008 | 09:05 PM
87 t-66's Avatar
not a drifter
no idea.
Old Oct 20, 2008 | 09:16 PM
ramello's Avatar
i have an extra ignition switch
Old Oct 20, 2008 | 09:17 PM
HAILERS's Avatar
HAILERS
The colors for the front harness plugs don't match the wiring diagrams.
One plug has two wires. One pure black and the other black/white.
Another plug has two wires. One is Black with a Red stripe and the other wire a pure Blue wire.
This does not match the colors you mention. I don't get it.
The ignition switch pigtail runs from the ignition fwd about a foot where it mates with the Front harness plugs. Are these the wires you talk of????????? That's what I'm talking about.
Then theres one wire by itself and it's Black/Red. Goes to the starter circuit.
See attached jpg.
Old Oct 20, 2008 | 09:28 PM
HAILERS's Avatar
HAILERS
See the fuse box attached? See the Meter fuse. That fuse and the other fuses on that row of fuses, only get powered up if the key is to ON or better.
The Black/White wire is the one that sends power to them from the igniton switch. Look again at the Black/White wire along side the pure Black wire in the two wire connector. When the key is put to ON, the contacts in the switch connect the pure black wire to the Black/White wire and power the METER fuse in the fuse box.
Your wire colors don't match the book. I've no idea why not. But I do agree that since you replaced the igniton switch......it ain't the switch. But I can't figure out why the problem exists BECAUSE your wire colors don't match the book NOR any of my cars ( I really need to go take another look at 'em).
I'll mull it over and look at my car tomorrow to try to see what's up.
Old Oct 20, 2008 | 09:38 PM
HAILERS's Avatar
HAILERS
Two of the three ignition switch plugs, are shown in the attached picture. The jpg is from another day...another problem. I do not show the third plug here. What I'm pointing out, is, is the black with black/white plug and the single black/red plug.
Why is yours different? Are you looking at another place?
Even the series five wires are Almost the same as series four. The exception is the single plugs wire.
Attached Thumbnails gauge cluster electrical problem.-plugs.jpg   gauge cluster electrical problem.-plugstwo.jpg
Old Oct 20, 2008 | 09:51 PM
HAILERS's Avatar
HAILERS
I've been talking Ignition Switch harness plugs. Your talking about OTHER plugs. What I suspect you have, is the wrong two plugs connected together. One I think is for the ignition key cylinder light and you have it connected to the clutch???? switches plug. Later. Not parts required if I'm right.
Just disconnet those two connectors. If you do that, will the car start? Will the gauges work with those two plugs disconnected?
Old Oct 20, 2008 | 10:02 PM
cambam3486's Avatar
i work for goodyear
when these two are connected my gauges and idiot lights work and stay on even without a key but i have to plug/unplug everytime i get in/out of the car
Old Oct 20, 2008 | 10:15 PM
cambam3486's Avatar
i work for goodyear
better picture of wire colors and connector
Old Oct 21, 2008 | 08:35 PM
cambam3486's Avatar
i work for goodyear
well i guess you all might be as clueless as me. cant find any other plugs for these to plug into except each other.
t-von
Sep 10, 2015 01:56 PM
vmerino
Sep 5, 2015 11:26 AM
