Turbo Ii Axles
Old Oct 19, 2008 | 05:27 PM
fc1990's Avatar
Arrow Turbo Ii Axles
alright i went down to Parts Plus and ordered my driver side rear axles for my rx7.i tell them mine is a turbo II cause im converting the drivetrain over to Turbo II. now when i get the axle and try to put it onto the rear end it wont bolt up. my question is is there a difference between turbo II axles from S4 to S5 rear ends . is the bolt pattern the same on the rear end.also this axles i got bolted up to my na rear end that i have out of the car .cause right now im pissed.
Old Oct 19, 2008 | 05:45 PM
Turbo II Rotor's Avatar
Who Shot the Sheriff?
You can't mix na and turbo drivetrain parts.
Old Oct 19, 2008 | 05:49 PM
87 t-66's Avatar
not a drifter
time to start looking for a turbo diff
Old Oct 19, 2008 | 08:49 PM
fc1990's Avatar
i know you cant mix axles . i have a turbo II diff on there right now . i ordered the drive turbo II axles for my car cause that was the only one i needed left and i ordered it for a 1990 turbo II . but when i tried to install it it wouldnt go on cause the pattern was different . but it would go on my old N/A rear end fine. do you think the parts store just mixed them up?
Old Oct 19, 2008 | 08:53 PM
Boost or Bust's Avatar
Rotorhead in the making.
It could still be a turbo II half shaft. It will fit on an n/a. There is about a inch of difference. If you have the other side I suggest you measure them.
Old Oct 19, 2008 | 09:25 PM
fc1990's Avatar
no the length isnt the problem its the bolt patteren on the diff. you know how there are 4bolts that hold the axles to the the diff. well on the turbo II one on my car the bolt patteren is bigger. that is what i mean by my axles wont fit onto the diff.
Old Oct 20, 2008 | 12:51 AM
RETed's Avatar
It's next to impossible to get turbo FC rear axles.
You have a non-turbo one.
-Ted
Old Oct 20, 2008 | 06:44 AM
Turbonut's Avatar
N/A axles
Old Oct 20, 2008 | 07:25 AM
Rob XX 7's Avatar
FC guy
929 axle will work, one side of them is a bolt on for TIIs, there is a thread on the v8 rx7 forum about it.
Last time I needed a TII axle my local autozone had them, I just ended up getting a used one instead, this was only last year.
Old Oct 20, 2008 | 02:34 PM
fc1990's Avatar
is a 929 rear wheel drive and what side works for them never heard of using that before. and i found only the passager side axle or i wouldnt trying to trcack driver side down.
Old Oct 20, 2008 | 03:21 PM
Alex Rodriguez's Avatar
MODERATOR
Veteran: Marine Corp
how much did you pay for that axle
Old Oct 21, 2008 | 12:42 AM
fc1990's Avatar
the one i got from Parts Plus which they just ordered me a new one i payed $75.
Old Oct 21, 2008 | 08:40 AM
MidnightOwl's Avatar
2 Rotors, 1 Turbo
They are more than likely n/a axles. If they don't bolt up to the turbo diff, they are n/a. I had to get mine from a forum member.
Old Dec 19, 2008 | 11:24 AM
SpideyFan6010's Avatar
Parker is my homeboy *)
TX
Yes the bolt pattern is smaller on a N/A than a TII. sorry man you got Shafted!
Old Dec 19, 2008 | 11:59 AM
jal301's Avatar
ANTI-REPUBLICAN
If you measure dist to centerline of the bolt holes i will do the same check when I get home today to confirm.
82streetracer
Aug 23, 2015 09:28 AM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
