Belt size needed after removing the air pump.
Old Oct 18, 2008 | 10:57 AM
mrb63083's Avatar
This is for a friend of mine with a 91' GTU. After removing the air pump, what size belt will he need to buy to replace the original one? I ditched the air pump on my FD a while back, but was not sure if the replacement belt was the same size as the one on the FC. (Hope all of that makes sense)
Old Oct 18, 2008 | 11:23 AM
jmkogut's Avatar
If you remove the air pump, it would be difficult to replace it with something else, beings how there's nothing to put it onto.
You friend needs a double alternator pulley, and two new alternator belts. Scrap the old alternator belt (It's probably a bit stretched by now) and use the two alternator belts to make sure your water pump doesn't slip at high rpm.
Old Oct 18, 2008 | 12:28 PM
Hecubus84's Avatar
Informed Appreciation
Exactly what I was thinking...
Is your friend aware that by removing his air pump he will lose 5-6th port and VDI functionality?
Old Oct 18, 2008 | 02:15 PM
Black91n/a's Avatar
Exactly. Take the airpump off to free up 1 or 2 hp and in the process loose 10-20hp from non-funtional VDI and 6 ports. Congrats, you're making way less power than before. Put the airpump back on.
Old Oct 18, 2008 | 03:25 PM
mrb63083's Avatar
I'll tell him, thanks guys.
Leeroy_25
Aug 17, 2015 12:53 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
