Horn wont turn off?
Old Oct 18, 2008 | 10:40 AM
rotary revolution 7's Avatar
Horn wont turn off?
I am having a problem with my 91 Non turbo FC. Well I have only been driving the car around my neighborhood lately every so often since the car is not inspected. Well I took it to my buddy's house and back and right as I'm about to make the last turn the horn starts going off by itself and wont stop. Its a constant horn also. Now every time I turn the battery on not even starting the vehicle the horn starts going off freely. I am thinking maybe the theft deterrent?? It doesn't make the beeping sound it used to make when I unlock it now either. Any ideas or suggestions?Any help is much appreciated.
Old Oct 18, 2008 | 12:14 PM
SDrotary-FC's Avatar
@ pipnorcali
does it have the stock steering wheel still?
Old Oct 18, 2008 | 12:24 PM
Turbo II Rotor's Avatar
Who Shot the Sheriff?
I'm guessing the horn wire is grounded somewhere behind the wheel.
Old Oct 18, 2008 | 12:44 PM
NoPistons!'s Avatar
Tango Down
Sound-proof your car so you can't hear it from the inside.
Serious note: Start chasing wires.
Old Oct 18, 2008 | 01:25 PM
Unplug the horn wire under the dash, I think you get to it without taking much apart. If that turns off the horn the problem is behind the wheel.
Old Oct 18, 2008 | 04:11 PM
HAILERS's Avatar
HAILERS
Or.... pull the plug off the CPU and then put a meter on the green/orange wire in the plug. Meter on ohms and see if that wire is grounded without the horn button being depressed. If there's no ground on that wire then the problem is in the CPU.
Or try something suggested in a post above. Put the batt cable on and then get in the car and rotate the steeing wheel full left and right and see if the horn stops honking when you do that. IF it does stop, then the problem lies in the horn switch in the steering assy. Been there seen/heard that before. Maybe be inside the car and have someone else put the batt cable on so the horn does not honk too darn much for the neighbors.
In case you missed it, the horn works by you depressing the button on the wheel which in turn puts a gnd on the green/orange wire which in turn causes the horn relay to pull in and put power on the G/R wire going to the horns.
Old Oct 18, 2008 | 07:36 PM
ericgrau's Avatar
Clean.
If you can pull the fuse until you get a chance to get it fixed. That way it's still drivable in the meantime. Then fix it, of course.
Old Oct 18, 2008 | 09:58 PM
HAILERS's Avatar
HAILERS
You might reconsider that idea. The horn runs off the STOPLIGHT fuse. You lose the stop lights. Not good. Remove the two connectors off the horns themselves would do the job.
Old Oct 19, 2008 | 01:43 AM
ericgrau's Avatar
Clean.
Heh, figures it couldn't be joined together with something more minor.
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
