hard starting please help!!
Old May 13, 2002 | 07:49 PM
NZConvertible's Avatar
I'm a boost creep...
Re: hard starting please help!!
Originally posted by chris-reed
I don't think that this is a voltage problem because my turbo timer reads 12.9 driving, and about 11 something sitting still.
I'm not sure if it's related to your starting problem, but you should see close to 12V with the engine off and 14.0-14.5V with it running. I'd get your alternator and battery checked soon.
Old May 14, 2002 | 07:30 AM
the alternator and the batt are new, The alt is stock mazda one, adn the batt is the red top optima
Still, those numbers are too low. I'd check them by putting a DMM on the battery terminals, taking a reading, then starting the engine and taking another reading. Should be ~12.0V and 14.0-14.5V, no less. At least then you'll know whether it's a crap voltmeter on the TT or a dodgy alternator/battery that might strand you...
i was told by a local guru here in town that its just the starter getting old. 140k on it..
I think mine's the same. Only 115,000km (72,000 miles) on it, but despite a new battery and good voltage it still cranks real slow. Starts every time though!
Old May 14, 2002 | 10:38 AM
Fingers's Avatar
chris, don't replace the starter yet. This is a very common problem that involves the starter not being fully grounded. Meaning, its trying to start off a very skinny wire. Try running about 2 feet of 4-gauge wire from the firewall to the engine block (behind the intake, there's a nice bolt) or directly to the alternator. (good bolt too)... i did that in my car, and the starter started up much nicely since then.
Old May 14, 2002 | 02:52 PM
blu_gxl's Avatar
try measureing the resistance of your neg. bat. cable.
Old May 16, 2002 | 02:06 AM
The Ace's Avatar
Greek Power
o k i grounded the engine, and it seemed like it worked. then it just started acting up again. When you go to start it, the starter makes crazy grinding noises and acts like its going to fall apart.
Does the sound seem like something is short-circuited ? You know, a persistent "buzzzzzzzzzzzz" or clicking noise ? Or does it come directly from the starter's electromagnetic "motor" ?
(god damn, I cannt believe I cannt remember the english word for the component that is made up from curled wire, you know, like "resistance, capacitor, and .......")
Seems like another electrical issue, or your starter is indeed starting to "die"....
Old May 16, 2002 | 02:20 AM
The Ace's Avatar
Greek Power
damn, thats just a nother hunder dollars down the ******* drain. "thats my turbo money" god!!!
Dont you have those "U-Pull" type of junkyards over there ? Seems like a lot of the guys here in the Forum have been very lucky in finding things for their Rexes. And I distinctly remember someone saying just yesterday that he has 2 almost new starters that he found in one of those junkyards, and paid only 15 bucks or something....
Th0m4s
Feb 26, 2019 02:04 AM
alphawolff
Nov 17, 2015 05:57 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
