Ebay Big Brake Kit
Old Oct 16, 2008 | 08:15 PM
Doc-1's Avatar
Doc-1
Ebay Big Brake Kit
Does anyone know anything about this item? Any good or should I just for-get-about-it
http://cgi.ebay.com/ebaymotors/BIG-B...=p4506.c0.m245
Old Oct 16, 2008 | 08:42 PM
Viking War Hammer's Avatar
*** Bless The USA
wilwood is good
Old Oct 16, 2008 | 08:57 PM
KaiFD3S's Avatar
SINFUL7
Thats a good deal
Old Oct 17, 2008 | 03:13 AM
DK's Avatar
DK
40k worth of fail
Originally Posted by Viking War Hammer
wilwood is good
Originally Posted by KaiFD3S
Thats a good deal
+1 ... Wilwood is legit. That's not an "eBay brand."
Old Oct 21, 2008 | 08:46 PM
Doc-1's Avatar
Doc-1
Okay I am going to get them. Where can I get the dust shields that will fit the rotors????
Old Oct 22, 2008 | 10:52 AM
M104-AMG's Avatar
They are good, but they don't fit under the stock 16-inch wheels.
Be sure to get their "fitment" template to test first.
:-) neil
Old Oct 22, 2008 | 11:25 AM
M104-AMG's Avatar
Also, since they are ONE-PIECE, VERY HEAVY . . .
They'll be nice with R-compounds . . .
:-) neil
Old Oct 22, 2008 | 04:21 PM
Doc-1's Avatar
Doc-1
I am running the 17 inch OEM wheels. I do not think I will have a fitment issue
Old Oct 22, 2008 | 04:29 PM
M104-AMG's Avatar
Nice!
BTW: you'll have to bend, cut, or remove your rotor splash shield. . .
:-) neil
Old Oct 22, 2008 | 04:34 PM
purerx7's Avatar
Registered User
How hard of an install is this?
Old Oct 22, 2008 | 04:42 PM
M104-AMG's Avatar
If you've changed your front rotors before, it's just a little harder because you have to change out brake-lines and do a proper brake bleed, as well as either CUT/Bend the splash shield.
The proper way would be to remove the splash shield, which may require removing the front hub which if I was going to do, would mean re-packing the bearings (washout out all the old grease), new seals, and a dial-indicator to setup the pre-load.
:-) neil
Old Oct 23, 2008 | 02:57 AM
DK's Avatar
DK
40k worth of fail
Just cut the shield with a dremel.
Old Oct 24, 2008 | 02:36 PM
purerx7's Avatar
Registered User
This is a dumq question and i have searched, but what size are the stock front rotors?
Old Oct 25, 2008 | 07:49 AM
sub9lulu's Avatar
11.6" for the FD
diabolical1
30
Jan 30, 2016 05:50 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
