Bucking Hesitation Under Full Throttle
Old Oct 16, 2008 | 06:46 PM
cyberxn's Avatar
Remove this account
Unhappy Bucking Hesitation Under Full Throttle
Well lemme Refraze that.
Under Half Petal Acceleration and Full.
IT bucks and Hesitates.
Areas that seem to be affected are in the area of 2K to 3.5K RPM and around 5 to 7K RPM
It feels like its possibly loosing spark or Fuel.. not sure.
Its got new plugs an Wires.
Problem is recent.
But im Completely Stumped.
Any help would be great
Old Oct 16, 2008 | 09:48 PM
cyberxn's Avatar
Remove this account
-bump- -thud- -falls over-
Anyone?
Old Oct 17, 2008 | 01:49 AM
cyberxn's Avatar
Remove this account
Im not sure why, But i got some crazy idea to Take my ECU out and check it..
Re Solder some of the contacts And it seems to of Improved it ALOT..
.. Stupid Exhaust overheat Light wont go away though.. stupid light
Old Oct 17, 2008 | 01:54 AM
KhanArtisT's Avatar
Former FC enthusiast
Could be grounds. You should clean them. Aaroncake.com has a write-up on it.
Old Oct 17, 2008 | 02:33 AM
Osirus9's Avatar
Jackstand Drifter
I agree, I would do some re-grounding. especially since messing with the ecu helped I'd say it's an electrical and not a mechanical problem.
Old Oct 17, 2008 | 12:03 PM
cyberxn's Avatar
Remove this account
O.o should i be able to see the ECU ground on my 7?
Not sure if i need to Remove my Upper intake for this <.< As i fear such things
Old Oct 17, 2008 | 01:06 PM
wvumtnbkr's Avatar
Sit and Spin
Check your TPS. Make sure it has no open ranges throughout its operating range. Check it several times repeatedly to ensure it is good.
Old Oct 17, 2008 | 03:30 PM
Chuck's Avatar
You might also want to check:
for clogged Cats
function of your secondary injectors
clogged primaries
Old Oct 19, 2008 | 09:07 AM
Snrub's Avatar
I agree with wvumtnbkr. I had a similar problem on my car. You have to check the resistance of the TPS while you slowly and steadily increase the throttle. If it's extremely jumpy then you have a problem. It's a difficult test to do because readings from multimeters take a minute to settle and it's hard to be super steady with the throttle.
Old Oct 19, 2008 | 09:35 AM
HAILERS's Avatar
HAILERS
Backprobe the green/red output wire and put the meter on VOLTS dc. Watch the reading as you move the throttle up/down. Your looking for *opens* or a reading that goes down as you depress the pedal and vice versa as you let off the pedal.
IF the car has been running good prior to this problem, then it's unlikely its the ECU grounds, since their under the upper intake manifold and would almost have to have been FOOLED with recently for them to go south.
Old Oct 19, 2008 | 09:37 AM
HAILERS's Avatar
HAILERS
Does the light go out when the sensor is disconnected?
Try that.
Old Oct 19, 2008 | 11:11 AM
cyberxn's Avatar
Remove this account
im going out to check the TPS now.
But i don't believe the Sensor is even There...
Old Oct 19, 2008 | 11:59 AM
cyberxn's Avatar
Remove this account
TPS seems to check out All Grand
I think it was a Ground Issue.. I Found J-rats Write up on it.. went threw it.. And it seems to of Fixed nearly 95% of the problem i was haven.. Now i must defeat the Evil Light that Refuses to DIE!!!
So where be this sensor? yarr
rgordon1979
40
Mar 15, 2022 12:04 PM
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
rx7shirley
Sep 2, 2015 02:11 PM
