3rd gen comon blown motor
Old May 13, 2002 | 05:38 PM
T88Rx7's Avatar
what are all the reason that these motor blow and what do people try to do to prevent it. What you think could be made to make them stronger. No dumb remarks PLEASE
Old May 13, 2002 | 06:33 PM
R1Outcast's Avatar
Originally posted by OneKrazyGuy
...And most importantly replace the stock stereo with a MP3 player/CD and Aux input with a 20 Gig Archos Juke Box...
Good one...very
Old May 13, 2002 | 07:33 PM
T88Rx7's Avatar
well i thank you very much. but im looking for answers not from coolent but internal engine block like seals housings springs ext. but again thanx for your reply
Old May 13, 2002 | 07:39 PM
Import Convert's Avatar
Well, coolant problems can lead t engine failure. If the air seperation tank goes, which they tend to do if not replaced with an aluminum one........ bye bye engine.
Old May 13, 2002 | 07:46 PM
T88Rx7's Avatar
how does that air seperation tank works
Old May 13, 2002 | 11:49 PM
rynberg's Avatar
There are two main causes for 13B-REW rotary engine failure:
*coolant seals - caused by overheating the engine, the comments made about coolant leaks and such are very relevant
*apex seals - caused by detonation-running too high of an A/F ratio, not adding more fuel when increasing air flow, too hot of intake temps, etc
Almost all stock cars suffer failure of coolant seals long before the apex seals give. This can also be caused by the simple process of heating and cooling off again. The twin-turbo rotary runs VERY hot.
Old May 14, 2002 | 04:26 PM
T88Rx7's Avatar
why would a stock FD detonate if there is no increase in air flow
Old May 14, 2002 | 04:43 PM
potatobbq's Avatar
who said that it would?
Old May 14, 2002 | 04:53 PM
Mahjik's Avatar
Mr. Links
I'm sure it's possible. I'm sure you can develop a problem with the fuel system or a condition that could cause the car to lean out...
Maybe running too low of an octane, or bad fuel filter....
Probably quite a few ways to make it happen, but they are probably not as likely to happen to a stock FD as they would be to a modified one.
As stated above though, probably the most common failure of stock FD is the coolant seals.
Old May 14, 2002 | 08:17 PM
dgeesaman's Avatar
You'll find out (when you start searching the FAQs and archives, hint hint) that coolant 'problems' are actually indications of bad seals and engine problems. In an FD, a bad engine results in coolant in the oil and vice versa.
Dave
Old May 14, 2002 | 10:47 PM
grinn253's Avatar
I also agree with onekrazyguy about maintaining the car to lengthen life of engine...I have 131,000 miles on original engine, however i did/do not take as much care as onekrazyguy does...
I do change oil every 3000 to 4000 miles however i always make sure it is full.
I ran out of gas 4 times
finally changed radiator after stop leak quit working
instead of sitting in car for a couple minutes, my neighborhood has a downhill (about 1 min) and i just coast for the trip.
I do open the hood for increased heat escaping when at home.
boost/lin temp gauge and fan mod as mods keep me cool
this procedure has kept my car 100% reliable for the past 4 years with 10-8-10 boost levels.
and a bunch of other little stuff that are always recommended by everyone here on the forum
However, it seems something went wrong just recently and now i have low compression on 1st rotor, so rebuild time for me. but i believe the rebuild is more do to age than my method of maintainment above. hehe.
anyhow Peace out!
Edgardo
