new rebuild
Old Oct 15, 2008 | 08:21 PM
mkivjacob's Avatar
89 gxl
new rebuild
not getting fuel please help
Old Oct 15, 2008 | 08:24 PM
Turbo II Rotor's Avatar
Who Shot the Sheriff?
Fuel pump turning on? Gas in the tank? Getting fuel to the rails?
Old Oct 15, 2008 | 08:28 PM
mkivjacob's Avatar
89 gxl
i have gas its turning on no fuel to rails
Old Oct 15, 2008 | 09:26 PM
Are you getting fuel to the outlet of the fuel filter? How about the inlet? How about the gas tank pickup?
Old Oct 15, 2008 | 09:45 PM
mkivjacob's Avatar
89 gxl
im getting fuel to the hoes after the filter when it is unhooked but not very much pressure i can stop the flow with my finger
Old Oct 15, 2008 | 09:54 PM
dkwasherexd's Avatar
Garage Life
your fuel pump is weak then, replace the fuel pump. Youll need alot of fuel pressure to start. That or ur fuel lines under the chassis is clogged or leaking. Did it run fine before the engine blew and the rebuild??
How many volts are you getting to the fuel pump?
Old Oct 15, 2008 | 10:07 PM
mkivjacob's Avatar
89 gxl
idk at this time how many should i get and what wire
Old Oct 15, 2008 | 10:11 PM
mkivjacob's Avatar
89 gxl
yea it ran when it blew so it might be a cloged line i will have to do more work tomarrow it a lil late right now
Vartok
16
Oct 8, 2015 04:49 PM
musker
Oct 1, 2015 05:58 PM
