Rearend noises
Old Oct 15, 2008 | 04:40 PM
Rotorhead34's Avatar
Scream baby Scream!!!
Rearend noises
The other day I was driving my 91 coupe and when I let off the gas this seriously ugly noise started. It sounds as if the rearend is coming out. But when I'm on the gas even lightly, theres no noise. Let off the gas and unload the rearend, the noise starts. I put it on stands and in gear and tried laying beside the car with my foot operating the clutch to duplicate the sound. I got it happen to a small degree but when it would do it the left rear tire would jump a little. The axles seem fine, the driveshaft seems fine. I first thought the driveshaft was loose, but its not. Anyone ever experience this?
Old Oct 15, 2008 | 04:53 PM
g14novak's Avatar
The Doctor
Need some info about the car first my friend.
Do you know how many miles are on the diff since the last rebuild(if it had one done) or fluid change?
Is the diff. a LSD or open?
Old Oct 15, 2008 | 05:01 PM
The diff is factory, 128k, lsd
Old Oct 15, 2008 | 05:36 PM
g14novak's Avatar
The Doctor
Try changing the fluid in it with Royal Purple gear oil. I hear its suppose to cut down on the noise of trannys and rear ends. Don't forget to put in the LSD additive either.
Thats about as much as I know about rear ends for these cars. Maybe someone else can chime in and help you out.
Old Oct 15, 2008 | 06:39 PM
jimieatgirl's Avatar
I had my passenger rear hub go out on me about 2 years ago, did about the same thing you are talking about.
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
Linda_Lovelace
Sep 18, 2015 10:04 PM
zxrazorxz
Sep 14, 2015 07:21 PM
