Megasquirt Throttle Position Sensor
Old Oct 13, 2008 | 09:59 AM
Ross80's Avatar
TX Throttle Position Sensor
What do you all use for a TPS. I am running a 13B FC NA motor and am trying to put it into a MGB GT. The stock throttle body does not seam to have a thottle pisition sensor, or am I an idiot and am not seeing it. If the do not, how do you all get around this?
Old Oct 13, 2008 | 10:07 AM
Aaron Cake's Avatar
Engine, Not Motor
The TPS of the 13B from the FC is on the front of the throttle body. It's a plunger type.
However I would suggest upgrading to a full range TPS. Grab a Ford style full range and make a bracket to connect it to the FC throttle body. Search the Haltech forum for instructions.
Old Oct 15, 2008 | 12:55 PM
Ross80's Avatar
Thanks for the help! I am sure I will have more questions later.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
