Ever wondered: "Damn, is all that smoke coming from my motor or the turbo?"
Old Oct 12, 2008 | 02:51 PM
philiptompkins's Avatar
Well here is how I'm going to find out.
I probably shouldn't share all these brilliant idea with the internet, but I'm sure it'll help most of you guys out at some time or another.
You can see here why I'm concerned that the turbo is leaking oil (return above feed)
And my solution is to pull the oil feed off and use my custom turbo stopping device to prevent damage to the turbo.
Old Oct 12, 2008 | 02:54 PM
13B-RX3's Avatar
7s before paint!!!
If you have not run the engine like this already i would not. The oil not only lubes the turbo but also cools the bearings. Without oil to cool the bearings the heat from the turbine wheel will rapidly transfer to the seals and bearings.
Old Oct 12, 2008 | 03:01 PM
arghx's Avatar
rotorhead
I would've built a custom turbo blockoff plate and let all the exhaust come out of the wastegate runner...
Old Oct 12, 2008 | 03:28 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
hahaha
fantastic.
Old Oct 12, 2008 | 08:16 PM
bob13bt's Avatar
Fixed the wheelhop
The best way to tell between engine smoke and turbo smoke is to remove the turbo and manifold, and install an N/A exhaust manifold. Then start the engine, if it smokes not only does that eliminate the turbo as a culprit, it will be very obvious if the seal problem is related to the front or rear rotor.
Old Oct 12, 2008 | 08:19 PM
jacobcartmill's Avatar
just dont care.
^ of course that would be ideal, but that's a little more complicated (and time consuming) than what the original poster is doing
Old Oct 12, 2008 | 08:47 PM
exactly, I don't have an n/a manifold that would fit this exhaust.
And do ya'll think it's going to hurt the turbo when I take it on my daily commute like this?
Old Oct 13, 2008 | 02:29 AM
Stanello's Avatar
backslash beanbagrace
I'd pull the turbo off, but leave the turbine housing on the manifold and make a piece of steel to block the hole where the turbine was.
Old Oct 13, 2008 | 09:06 AM
7dust's Avatar
Irregular Here
Phil,
I have not had nearly enough to drink before I read this post.
However, in a moment of clarity and since there is actually some blood in my alcohol stream...
How come you just don't switch the oil feed / return lines and install a restrictor? I mean does the turbo actually care which direction the oil comes from?
Old Oct 13, 2008 | 11:33 AM
ITSWILL's Avatar
Wiring Nightmare
what do you think is going to happen when that area heats up from the turbo manifold?
Old Oct 13, 2008 | 11:50 AM
Originally Posted by chaosseven
Phil,
I don't know, its a good question.
Chuck knew what the reason was why we coulden't switch them.
Old Oct 13, 2008 | 12:00 PM
Newbie
To me it seems like there is a pretty good probability that the wrench could get shaken just a little bit and when it does all the fishing line/zip ties are going to do is prevent it from falling AWAY from the turbo, and actually push it right into the compressor wheel...
I think when it comes to things like this it's better to do it right the first time, typically if something isn't already widely known as a good diagnosis method there's a reason... More power to you though! I'm interested to see how it turns out at the very least .
Old Oct 13, 2008 | 12:47 PM
Well I know you guys are curious so here is an update: After about 45 minutes of driving this morning there was almost NO smoke (just a lil on startup). Wrench stayed put but the compressor housing did get toasty. So on my way home a stopped by home depot and made my custom boost controller (needle valve) fit the oil feed line. Now I have a flow regulator.
The feed for the turbo comes from the custom pedestal, which does have a fairly small hole but is unrestricted. I thought the oil flow to the turbo may be too high when, after plugging up the oil feed, I noticed my oil pressure is about 30PSI higher than before.
So now I have the needle valve cracked a half turn open, which dropped my oil press. by about 10psi, and while bench testing the air flow (blowing through it by mouth) of the valve, I saw some flow by 1/2 turn, and mostly full flow by 3 turns.
Now I'm thinking I'll just set the oil like timing, advance it till it smokes, then back off a lil.
Old Oct 13, 2008 | 01:19 PM
thetech's Avatar
****** of disaster
Wow at this. Just wow.
Old Oct 13, 2008 | 02:36 PM
7dust's Avatar
Irregular Here
I think there should be a drink minimum before opening any of your threads.
Old Oct 13, 2008 | 03:10 PM
Newbie
You drove the better part of an hour without oil flow to the turbo? and no air filter? with a wrench holding the compressor wheel stationary?
I will admit I am very impressed the wrench stayed put! Not surprised that the turbo was a bit warm! Still interested to see where this goes though .
Old Oct 13, 2008 | 03:53 PM
Question: What oil pressure should I see between the restricter and the turbo?
Old Oct 21, 2008 | 10:17 AM
i know you guys were hoping for a epic fail with a destroyed turbo, oil explosion, and a motor eating metal....but I've put about 800 miles on the thing with the valve and it seems to be working good. I kinda like the idea of being able to "crank up" the oil pressure when you know the turbo is fixing to get hot.
Old Oct 21, 2008 | 01:23 PM
jkstill's Avatar
Searching for 10th's
One way to see if it is just the motor is to check the intake and spark plugs for oil.
oil on plugs + no oil in intake = smoke from motor
What this doesn't tell you though is if both are leaking, or if just the turbo is leaking.
Oil in the intake can cause oil on the spark plugs.
But if the intake is clean and the plugs oily, it's likely just the motor.
A place to start anyway.
Old Oct 21, 2008 | 04:22 PM
but the problem is, all my plugs are screwed all the time and its probably because of my screwed tune. black plugs = rich.
Old Oct 21, 2008 | 04:33 PM
classicauto's Avatar
Crash Auto?Fix Auto.
Why not take off the turbo and look in the exhaust manifold runners/exhaust sleeves?
Old Oct 21, 2008 | 07:09 PM
jkstill's Avatar
You can probably tell the difference between carbon and oil.
Oil will look wet, just carbon won't.
Old Oct 26, 2008 | 09:29 PM
2Lucky2tha7's Avatar
Back at it again!!
Sorry, I can't help it but.......lol @ you! why did you open another thread to show what happened to your turbo because you did this? Why not just post the pics in here? I knew this was going to end badly...
You are one silly man.
Old Oct 28, 2008 | 12:26 PM
Calenrow's Avatar
Newbie
This, friends, is what you call a modern marvel of engineering.
Old Oct 29, 2008 | 06:50 PM
catch-22's Avatar
this is the funniest thing ive ever read. just fantastic.
