2 unkown cables
Old Oct 11, 2008 | 01:34 PM
renedis's Avatar
2 unkown cables
I have a question. the garage stripped my rx-7 because of a excident.
but now i have to put the car back together my self.
i'm pretty much done but i have 2 cables left..
can you guys tell me what it is?
i searched the forum but without succes!
thnx in advance!
cable on the frontbumper, it's not the cable of the claxon!
and what is this cable?
Old Oct 13, 2008 | 12:28 PM
renedis's Avatar
no one knows?
Old Oct 13, 2008 | 01:40 PM
Smitter's Avatar
94 Single Turbo FD
the black one looks like it could be for the horn or maybe the marker lights,test some stuff and see what is not working. not sure about the white one though
i got the front end of my car all apart right now i will go see if i can find that white plug. where does it lead from?
Old Oct 13, 2008 | 03:02 PM
renedis's Avatar
the black one is not from the horn, i tested it. everything works to.
the white one.. check te picture:
the red line made with paint show the start of the cable.
thnx for checking!
Old Oct 13, 2008 | 05:54 PM
badddrx7's Avatar
All Spooled Up
The first one is the side marker light connector, it's busted up some.
The second one is......give me the exact wire colors attached to it.
stay tuned
Later
Old Oct 13, 2008 | 06:50 PM
Smitter's Avatar
94 Single Turbo FD
badddrx7 is the wiring master. all hail
Old Oct 13, 2008 | 09:52 PM
IRPerformance's Avatar
Sponsor
The 2nd connector is not oem
Old Oct 14, 2008 | 05:21 AM
badddrx7's Avatar
All Spooled Up
"The second one is......give me the exact wire colors attached to it."
Oh well, Smitter must not want to know after all...on to the next problem.
Later
Old Oct 14, 2008 | 07:32 AM
renedis's Avatar
stay tuned
Later
pretty weird, both of my side markers are working fine.
the colors on the second, i will check tonight.
Old Oct 14, 2008 | 03:18 PM
renedis's Avatar
2 unknown cables AND weird 1000 rpm idle (last post)
back with pics and another problem
first, the white cable connector:
the cable has 2 wires, the colours are:
1. black/white
2. red/blue
and here's another picture from where it leads: (sorry for the bad quality)
and my next problem.
i started the car with no problem as usual and drove it to the garage (max 50 meter/160 feet).
i fitted the frontbumper+ headlightcovers and i started it again to call it a day.
but when i start the car it runs max 1000 rpm idle. there is continuous flowing air out of the BOV and the airfilters are sucking in air like a madman.
KLIK i have made a video to be more clear about this problem. the gauge you see in the video is the boost gauge. KLIK
thnx again!
Old Oct 14, 2008 | 10:06 PM
badddrx7's Avatar
All Spooled Up
The first one has to be either the marker light OR parking light in the turn signal.
The white connector is not showing up anywhere. YOU need to do some better research on where it goes and some better camera work if you are really into this and want to solve it.
Later
Old Oct 15, 2008 | 08:24 AM
renedis's Avatar
Later
Ok thanks.. i will look if i can find out where it leads to.
TeamRuffRacing
Sep 30, 2015 08:13 PM
rattlehead
Sep 25, 2015 10:55 PM
