bnr sIII twins
Old Oct 8, 2008 | 10:43 PM
RX7 allnight's Avatar
bnr sIII twins
could i use these on a brand new (not rebuilt) non-ported 13b-rew motor with the stock ecu and injectors with low boost?
Old Oct 8, 2008 | 11:07 PM
IRPerformance's Avatar
Sponsor
Sure, you will just be limited to about 10-12 lbs of boost.
Old Oct 8, 2008 | 11:56 PM
moconnor's Avatar
What are the AFRs going to be at 12 psi with these turbos with the stock ECU given their presumably significantly greater flow rate?
I know that back in the day M2 recommended not going above 10 psi untuned with their sequential twins - and that was with their stage III ECU.
I'm assuming you have personal experience logging AFRs above 10 psi with the BNRs on the stock ECU?
Old Oct 9, 2008 | 09:22 AM
tafkamb2's Avatar
You would more than likely have to turn the boost down untill you upgrade your fuel system. Unless you want to blow your engine.
Old Oct 9, 2008 | 07:05 PM
Monkman33's Avatar
Goodfalla Engine Complete
do not ever go above 10 psi on the stock ecu. plain and simple.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
matty
40
Oct 6, 2015 09:13 PM
