LOOK!!!! 88 Vert Initial Start Up!! Pics and Videos Inside!!!
Old Oct 4, 2008 | 09:12 PM
cpubugs's Avatar
Lovin my 7
Ok, so as the title states this is my 88 Vert's first starting. But before you look at all the pictures I'll give a run down of how it came to be. But first I want to roll the credits here, because with out the help I got I would not be posting this. First I have to, and am honored to thank Alex (El Nene) with "ROTOR7VEN" and for undertaking this project and stress. Second I have to give props to Banzai Racing for their excellent customer service and what I consider a superior product to any I have seen or saw while looking to purchase block off plates for the emissions and omp. Also the shipping was pretty darn fast. I ordered Tuesday morning and had the plates in hand Friday afternoon. There was also some awesome and quick phone support added to the days work I believe it was "Fritz" with Lucky 7 Racing (correct me if I'm wrong). And last but not least I have to thank every one on this forums and all of the other rotary forums.
Ok now for the story.
If you click the link in my sig you can get the longer story. Basically started an s4 to s5 JDM TII conversion back in April of '06 made a lot of quick un-researched buys and just wasn't ready to purchase the motor yet. Well around December or January maybe later in '08 I traded my JDM TII motor and tranny for the 88 vert. The owner at the time blew the motor and some friends of mine replaced the motor, but they never had it running after that. And that is how i received the car. I was told hey it was either a ECU or fuel pump. So I replaced both. Also replaced the coil packs, the alternator, a few misc odds and ends and never did get it running. So I tried to sell it several times but my $1000.00 price tag was too high for everyone that was interested. So it sat and sat... Well almost 3 weeks ago I was in an accident in my civic (my daily driver) being that it was a 94 and the damages where in excess of 4K, they totaled it. and gave me a check for $1500. About this time I get a PM from El Nene asking if I would part with my fuel tank. After a few minutes of conversation he had agreed to help get my Vert on the road.
So..... he suggested since it was down and we were going to need to redo lines and hoses to remove the rats nest and omp, to which I quickly agreed. Next thing I know he is at my house picking up the beast. He stripped off the 4 million miles of hoses and 200 pounds of environmentally friendly BS (obviously not actual measurements) and then we waited and waited for the block off plates. (My fault not Banzai's BTW) Anyway enough of the boring stuff plus I haven't eaten all day and I'm hungry so I'm ready to stop typing. We/He got all the plates on, capped off all the vac. lines that are no longer needed and put everything back together. Then it magically started after sitting for a year or more... Ok no not really. We swapped ECU's we swapped fuel pressure regulators, fuel injector relays, and we did lots of voodoo dances there was chicken bones and candles it was great. Well it still didn't start.
Alex and his brother were able to get it running for a bit with starter fluid and heard a terrible knocking at about 3000 rpm. Well after i heard it and saw the amount of smoke pouring from the motor and we all thought the motor was blown. So we were all down/pissed/depressed for a few minutes... Then he asked what I wanted to do. I was like "screw it!" if it's blown what are we going to hurt (tis was more out of frustration than hope) we started talking and were both kinda hoping it was a stuck seal or something from sitting so long. So I said lets keep trying it. so he was spraying starter fluid and I was turning her over and over and over and finally he stopped spraying and I was keeping it running with just gas. slowly revving higher and higher holding it at high rpms finally getting her to 8000 (with 5th and 6th ports closed) and there was lots of smoke!! finally we tried to let it idle and she cut off. He found a vac leak and capped it, then the next start he was going to start spraying starter fluid in and it started all on its own. Once it got to a decent temp it idled down to about 1000 and stayed running. NO zero zilch smoke this time. the video of this is really just audio because it was dark.
Anyway the videos are in order of attempts. Only the last 2 have the proof.
Here are the Videos, they are mp4 format so if you don't have quicklime or real player find your self a mp4 codec and install it. You may need to "right click" and choose "save target as" save them some where then open them.
1st Attempt
2nd Attempt
3rd Attempt
4th Attempt
5th Attempt - Success!!! But no Idle and lots of smoke!
6th Attempt - Success !!! Decent Idle and no smoke
Pics of some of the removal and install of the plates and such (in order of time I took them):
cpubugs's Avatar
Lovin my 7
Old Oct 4, 2008 | 11:21 PM
blackedoutFC3S's Avatar
HKS obsessed
nice man! glad to hear you got it started up! good luck on all thats to come bro
Old Oct 4, 2008 | 11:30 PM
Alex Rodriguez's Avatar
MODERATOR
Veteran: Marine Corp
hey Kyle i cant see the vids , see if you can photobucket it
by the way, for those of you who are reading about this car keep in mind when a engine sits for a long time seals do get stuck and you are more prone in blowing your engine than revving your every day car to redline for bit.... a minute or two...trust me i have seen it done it took the guy 5 minutes to blow a rotary
What i suggest for someone about to store their car for a long time is...(over 10months )
- run premix for a day or two before storing the car- it will help with getting the seals and springs lubed up a bit
- drain the fuel tank-
- remove the battery
- get a small bowl fill it with baking soda and put it on the passenger side floor - helps with moisture, old plastic smell , and cracked plastics!!!
- cheap wheels and tires or lift your car on stands , so you can prevent flat spots or cracking
- get oil and lube the tires sidewall and threads- helps with cracking
Again those are suggestions and what i believe can help in keeping you car stored and maintained in good shape
As for Kyle - CPUBUGS the man was down and in need of help we worked a deal out and we are both happy, i am doing work on the side now because i dont anything better to do with my time so i am accepting work until further notice- Again i will not rape you i rather help get you on the road than make a killing on getting paid
Alex
Old Oct 4, 2008 | 11:35 PM
MODERATOR
Look how sexxy that motor looks with out the emissions and crap
cpubugs is now going to clean and degrease the engine bay, and it will look like new
5th and 6th ports are next- we are going to fully remove them and possibly hook up a set of racing beat headers stay tuned
Old Oct 5, 2008 | 01:57 AM
cpubugs's Avatar
Lovin my 7
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/EO8BQu-sl_U&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/EO8BQu-sl_U&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/yGIkTAOF8yo&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/yGIkTAOF8yo&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/qkrxwFBTJVY&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/qkrxwFBTJVY&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/mF8Rcv-QKmg&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/mF8Rcv-QKmg&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/kV5lc9UqeW4&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/kV5lc9UqeW4&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/YOdfXgjo75M&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/YOdfXgjo75M&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
Old Oct 5, 2008 | 02:02 AM
MODERATOR
post the other one withe start up smoke...lol
Old Oct 5, 2008 | 02:12 AM
cpubugs's Avatar
Lovin my 7
How about imbedded youtube?? Can everyone see them now?
It's the second to the last one.
Old Oct 6, 2008 | 08:22 AM
cpubugs's Avatar
Lovin my 7
Ran in to a small snag. (big suprise to all I am sure) Water pump was bad. thought I had one off of my other motor but have been unable to locate it so I have to purchase one. on the flip side got some more video of the car running and Alex getting it to idle properly. As well as adjusting the crank angle sensor to find it's "sweet spot" I will post it up asap! Got to take it for a very short spin due to the water pump, it was very short.. Going to get it out of Alex's hair this eveing after work as his job is done now. And I will baby this motor for a few paychecks while i save for a rebuild. But she sounds good and wow.... talk about loud.. no mid pipe so just racing beat headers and good old florida air. lol
Old Oct 11, 2008 | 07:02 PM
cpubugs's Avatar
Lovin my 7
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/zi7VvCIZ98s&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/zi7VvCIZ98s&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
El Nene molesting my car. lol Getting it to idle around 1100 and adjusting the timing a tad. She was up and running for about 5 minutes this is when we found the water pump issue. Then I took it for a little drive, promptly bringing it back and turning it off.
Old Oct 11, 2008 | 07:22 PM
cpubugs's Avatar
Lovin my 7
Update:
- Tuesday 10/7/08 - Towed the car from El Nene's to my moms and dropped it off.
- Thursday 10/9/08 - Got the water pump swapped, replaced all the belts, changed the oil and filter.
- Saturday 10/11/08 - I went and swapped the RB Street Race headers for the stock manifold until I get the rest of the RB system.. Also went and had four tires put on my rims. Took her for about a 5 mile drive went to the gas station, added my premix and filled her up. Noticed the temp rising a bit on the way back so going to figure that out tomorrow... Possibly a thermostat i don't know. Noticed that the hoses were under quite a bit of pressure and I knew that the system was not vented so I let her cool a bit and then relieved the pressure. After that pulled the plug on the top of the radiator and plugged a fitting in and ran the hose to the over flow tank however it still seems as if its running too high so I am going to do a few things tomorrow about that 1, replace the thermostat and 2 flush the system to make sure the radiator isn't clogged. After I finish cleaning the engine bay I will replace the under carraige plastic air dam deal and place the fan shroud where it should go. Anyother Ideas?
Tomorrow I should be getting the replacement top and hopefully the seats to go with it. down sizing the video of today to put on youtube as soon as i get it done i will post it.
Old Oct 12, 2008 | 11:39 PM
cpubugs's Avatar
Lovin my 7
What Actually happened today... went to a friends shop and yanked a 90%better top. s5 black interior and a few other odds and ends. left and right side motors for the top, full exauhst system, temporary until i get the exauhst I want black leather seats with the head rest speakers, misc black s5 trim interior snaps and screws the amp or control deal for the head rest speakers and one bbs center cap. I think that was it anyway, grand total 225 bucksI had to pull it all and then go put it on my vert. got the thermostat and changed that but its still over heating the fan clutch seems to be ok so tomorrow or wednes day I am going to try and flush the system and bleed it see if that cures the problem. Any one rin their sven in FL with no thermostat?
Old Oct 13, 2008 | 12:54 AM
Osirus9's Avatar
Jackstand Drifter
I love it when RX-7's come back from the dead. especially when people are so excited about them lol
great job! and keep posting videos!
Old Oct 13, 2008 | 09:37 AM
loquin23's Avatar
i know the guy in the drivers seat looks like he is glowing, lol
everyone though i got laid by seven girls at once after i started mine when it had been down for quite sometime.
freakin skipping around like a lil schoolgirl....lol
Old Oct 13, 2008 | 04:22 PM
duo2999's Avatar
Pabs
lol this is awesome. i recently got a black 88 vert about 2 months ago and we already have her working.
needed quite a bit of parts like a gas tank, fuel pump, complete exhaust system, water pump, and clutch and pressure plate.
but now i have mine running and i know that the feeling of having it running is amazing!!
Old Oct 13, 2008 | 05:17 PM
87 t-66's Avatar
not a drifter
someone is pretty ballsy putting their hand so close to the fan with the motor running. congrats.
Old Oct 13, 2008 | 06:00 PM
MODERATOR
ahhhuuuhhhhmmm get get get it boyeeeeee
Old Oct 13, 2008 | 07:42 PM
cpubugs's Avatar
Lovin my 7
OK!!! Some what of a successful day. I was so worn out from cracking at it all day Sunday and my back hurt so bad I didn't go to work... took a few muscle relaxers and went back to bed. got up around 1 and started working some more. Put the fan shroud on and pulled the thermostat all together. Decided to let it run a bit and yep still over heated.. So..... I decided to tighten the belt a little more and TADA!!! or so I thought. I took her for a drive probably close to 50 miles and she didn't over heat. she stayed very very low actually around the bottom of the guage. Until I took her on the highway went about 10 miles and noticed she was getting a bit warm so I pulled over at a station and proceded to top off the water and sure enough she was over flowing and boiling. So I am some what encouraged and discouraged at the same time.
Old Oct 13, 2008 | 11:52 PM
Osirus9's Avatar
Jackstand Drifter
dual alt pulley time?
and did you ever replace your thermostat?
Old Oct 14, 2008 | 11:52 AM
cpubugs's Avatar
Lovin my 7
not sure why this got moved to "non technical" seeing that there are questions and answers as well as pics and videos... but Ok...
Yeah Im thinking dual alt pulley as well... Until I find an electric water pump...I already have my taurus efan. ill just put a portable fridge in the damn trunk and coil hose up in side and pipe it in to the coolant system... This is the ONLY issue stopping me from driving her... oh and no, still have no thermostat.. I mean i have the one that came out of it and the one I bought to replace it, but I will put it back. AS soon as I see a reason for it. I really don't see a need for it... and I have never run one in any of my other cars that I've ever had. But I will trust someone who gives me a logical valid reason...
Old Oct 14, 2008 | 08:48 PM
cpubugs's Avatar
Lovin my 7
Latest addition to the video lineup
<object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/h10p_VzSz8g"> </param> <embed src="http://www.youtube.com/v/h10p_VzSz8g" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
Old Oct 14, 2008 | 09:00 PM
cpubugs's Avatar
Lovin my 7
Incase your wondering what I am looking at in the first few minutes it was leaking power steering fluid. Tightened the high pressure hose fittings and vala!
Oh and my mom was yelling in the back ground "Your gonna throw a rod" lol
Old Oct 14, 2008 | 09:14 PM
riptyde's Avatar
The Addiction of Wankel
i wish my oil pressure was that high
Old Oct 15, 2008 | 08:33 AM
cpubugs's Avatar
Lovin my 7
careful what you wish for, mine may be too high....
Old Oct 16, 2008 | 07:46 PM
MODERATOR
looking good bro
