Haltech E6X wont start, runs perfect when warm outside
Old Oct 1, 2008 | 09:48 AM
arsinal4496's Avatar
brap, brap, pop
Have a E6x installed on my fc. Car was running tip top and one day in the early morning i go in to start it and it didnt. Car cranks but doesnt start. So far i have confirmed that i have fuel and spark . Iv noticed i only have the problem when its cold outside. When its warm outside it runs perfect. I even ran it to seven stock and back with this condition (was a b**** to start that morning and only managaed to start it around 11:30am). Any ideas on what it might be? or if its even the haltec? AIT sensor maybe? Thanks in advance.
austin
Old Oct 1, 2008 | 11:03 AM
Claudio RX-7's Avatar
EFI Tech Wannabe
Corrections! Corrections! Corrections! Its all about corrections, coolant temp, air temp, post start enrichments, throttle pumps, etc.
Old Oct 1, 2008 | 11:21 AM
brap, brap, pop
saying it could be anyone of those and some?
Old Oct 1, 2008 | 11:28 AM
EFI Tech Wannabe
Yes, its basically tuning. A cold engine requires different fueling and timing than a warm one.
Old Oct 1, 2008 | 11:54 AM
brap, brap, pop
feared it might be that. that brings me to my next question. why did this happen all of a sudden? iv turned on the car in much cooler temps with no problems. seems like i might have to get it tuned
Old Oct 2, 2008 | 07:35 PM
RETed's Avatar
Why do people blame components when something goes wrong?
It sounds like the PRIMER or cranking map needs to be adjusted on the colder ranges.
I dunno what you mean by tuning-in-colder-temps, but adjusting the PRIMER map in the cold ranges is a royal pain in the ***.
Did you really crank / adjust map / let motor cool down / repeat for this???
-Ted
Old Oct 3, 2008 | 01:16 AM
brap, brap, pop
reason i started thinking it might be sensors was because it was running fine before even in pretty cool temps and all of a sudden it wouldnt start. just thought it might be a sensor that went wacky, i dont know, thats why i posted here to see if i could find whats going on. and as far as messing with the map, i think im going to leave that to the pros for now, as this is my daily and dont know to much about tunning so far
Old Oct 3, 2008 | 01:20 AM
brap, brap, pop
feel free to correct, thats why im here to read and learn. just dont be too mean
Old Oct 3, 2008 | 08:25 PM
RETed's Avatar
If you have access to the comm program, you can monitor the sensors directly to see if there is anything weird about them.
-Ted
Old Oct 4, 2008 | 04:21 PM
brap, brap, pop
my stupid laptop died about 3 months ago, i was actually thinking of just taking my whole pc out there haha
Old Oct 4, 2008 | 06:04 PM
BASTARD's Avatar
you could take your PC out there... or you could just sprinkle pixie dust over your car and wave your magic wand at it... in the meantime I will look into my Chrystal ball and figure it out
Old Oct 4, 2008 | 06:08 PM
EFI Tech Wannabe
Take it to a reputable tuner that will be able to tackle the cold starts as well as other corrections.
Old Oct 5, 2008 | 01:45 PM
brap, brap, pop
^^exactly what im gonna do, just hooked up my pc and all sensors seem ok?
Old Oct 5, 2008 | 05:44 PM
BASTARD's Avatar
im sure its a correction map that needs to be tuned... also have you tried reloading the map?
Old Oct 6, 2008 | 12:03 AM
brap, brap, pop
i dont have the map, car came with it. dude from illicit performance should be coming down to check it out. hes the one who did the install and tuning.
Old Oct 14, 2008 | 11:02 PM
brap, brap, pop
turns out i had no rpm signal. would get it and then just go out. there was trouble with ground interference from the starter it seemed. i grounded the battery straight to the tranny/starter bolt, then briged it to the frame. and boom, i have rpm signal. shes running like a champ....for now at least thanks for the input guys
Old Oct 15, 2008 | 10:03 PM
brap, brap, pop
celebrated alittle too soon. rpm's died again today
Old Oct 16, 2008 | 12:49 PM
classicauto's Avatar
Crash Auto?Fix Auto.
I've ran into this issue on my FC before and it really got bad when BDC was up here.
We were tuning the car one eve, I went home, tried starting it the next day but got no RPM signal. I had to lower the gains/filters for it to get signal.
Then after running for 15 minutes signal completely cut out....had to raise the gains back up to get signal on the now warm engine.
I replaced the CAS with another and using the gains/filters I had originally it worked fine.
I suspect the CAS magnets were perhaps weak or aging and the signal they would put out when hot required more filtering for the ECU to make sense of........but when they'd cool off and become stronger, the signal was different enough to warrant changing the gains. I have no idea why it did though - just my hypothesis.
Old Nov 9, 2008 | 01:08 PM
brap, brap, pop
The ra10 fixed the problem right away. its running fine now. when its cold it doesnt idle as well as it did before but once its alittle warm and driven on, idles just fine........what a pain in the *** this problem was....
Kyo
Apr 13, 2019 09:24 AM
sherff
Feb 24, 2019 12:09 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
PhillyFC
Aug 21, 2015 06:36 PM
86glxNA
Aug 18, 2015 03:33 PM
