Haltech Retaining memory question
Old Sep 29, 2008 | 07:46 PM
beefhole's Avatar
Boosted. I got BLOWN!!!
Question...
Does the haltech retain memory if the battery is unplugged? I wonder because I have my car awaiting rebuild for the past year, everything is undone. I saved my map on my laptop, while my car was running long ago. Do I need to reload it into the haltech (E6K) before I fire up the rebuild or is it already there? I don't see how it retains any maps (with the exception of a default built in) unless it has power or an internal battery backup. Is this correct?
Old Sep 29, 2008 | 08:20 PM
TweakGames's Avatar
FD pro licensed driver
yes my e11v2 does. Would be pretty stupid if it doesnt. You leave your lights on and drain your battery, and your ECU is wiped. O.o
Old Sep 29, 2008 | 08:29 PM
beefhole's Avatar
I don't know much about these computers, I was curious as to how the memory (if it is) retained without power. Yes it's a silly question, just a little worried about my upcoming first start (my first rebuild).
Old Sep 29, 2008 | 09:13 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
This is constantly asked time and time again, when you disconnect the battery on your modern computer controlled car, does it loose its programming? no... Haltechs and pretty much all engine management systems are the same way.
If your car behaves differently after having sat with no battery for too long, the problem is outside the box. They have what is called "none volatile memory" which means it will not erase EVER! if its not done electronically. So, sitting in a box for 10 years, yeah, no, it wont loose its programming. Unless of course, you decide to weld on your car or put a battery charger set to high with the ECU still connected which would probably fry a few components in it.
If, however, your engine is different than what it was originally tuned for (which it probably is), there will most certainly be a need to retune it. So bare that in mind.
Old Sep 29, 2008 | 09:30 PM
beefhole's Avatar
Thanks! I admit, it was s totally stupid question, I kind of knew the answer anyway. Still... peace of mind.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
