Peicing together KIT, where should I get nozzles, jets, one way valve and fittings?
Old Sep 28, 2008 | 07:20 PM
Viking War Hammer's Avatar
*** Bless The USA
I just need lines, nozzles, jets, fittings and a one way valve.
Where should I get those from?
Or, should I just order it all from here http://www.alcohol-injection.com/wat...ction-parts-3/ ?
Old Sep 28, 2008 | 07:24 PM
*** Bless The USA
Also, I need to run two nozzles. Should I just run this T-Fitting on the main line?
Old Sep 29, 2008 | 04:20 AM
Shaman's Avatar
You might look into Aquastealth, I know that their nozzles were cheaper.
Old Sep 30, 2008 | 01:57 PM
*** Bless The USA
But, is my idea what people do.............. if you're running duel nozzles, you just use a T-fitting like above?
Old Sep 30, 2008 | 05:39 PM
Shaman's Avatar
Yeah, a t or y fitting
Old Oct 3, 2008 | 06:05 AM
*** Bless The USA
Exclamation
Okay, I have the following parts and need to know what else I need.
1. 3 bar progressive controller
2. Methanol tank
3. Shurflow 150 psi pump
Now, what else do I need?
1. 2 Nozzles.
2. 1 checkvalve.
3. Hose
4. Instant Fittings
5. Misc npt fittings.
Is this basically all that I need?
Old Oct 3, 2008 | 06:26 AM
Shaman's Avatar
May be on there, but make sure you have a way to get th fluid out of your tank.
Old Oct 3, 2008 | 06:40 AM
*** Bless The USA
It's already got a fitting on the tank, is this what you mean?
Old Oct 3, 2008 | 06:41 AM
*** Bless The USA
Also, do I need a check-valve on each nozzle or do I just need one coming off the pump?
Old Oct 3, 2008 | 03:18 PM
devilsown's Avatar
Viking War Hammer, you want to run the check valve before the y. Never run more than 1 check vavle in a system.
Shaman comparing our nozzles to there is kinda like comparing apples to oranges.
Old Oct 8, 2008 | 10:12 AM
*** Bless The USA
Can I run that check valves right off the pump, or does it need to be closer to the y fitting?
Old Oct 8, 2008 | 02:00 PM
*** Bless The USA
just ordered the remaining parts to complete my kit
1 x Brass Check Valves - 1/4 Tube to 1/4 Tube 2116 0% $30.00 $30.00 $30.00 $30.00
1 x Y Union Instant Fitting 3013 0% $4.65 $4.65 $4.65 $4.65
2 x Outside Mount Nozzles - DO14 2714 0% $20.00 $20.00 $40.00 $40.00
2 x 90 Nozzle Holder 3010 0% $6.25 $6.25 $12.50 $12.50
2 x Straight M Instant Fitting
- Fitting Size: 1/8" Npt 3015 0% $4.55 $4.55 $9.10 $9.10
1 x Bulk Male Fitting 3018 0% $4.95 $4.95 $4.95 $4.95
10 x Nylon Tubing 2009 0% $0.75 $0.75 $7.50 $7.50
United Parcel Service (1 x 1.11lbs) (Ground): $8.58
Sub-Total: $108.70
Total: $117.28
Old Oct 8, 2008 | 08:24 PM
AlexG13B's Avatar
brap brap brap
cool i should be ordering the rest of my stuff this week as well :0
Old Oct 8, 2008 | 08:58 PM
*** Bless The USA
Yep, my stuff will be here Friday so I'll be posting pictures of my install this weekend. 2 nozzles directly into the turbo
Old Oct 8, 2008 | 09:05 PM
AlexG13B's Avatar
brap brap brap
Nice. i wanna see keep us updated. i should be getting all of my pieces in bout 2 weeks
Old Oct 23, 2008 | 02:43 PM
Comitatus's Avatar
Down for the count...
Nevermind...
Th0m4s
Feb 26, 2019 02:04 AM
