Exhaust system glowing red-hot after replacing cat. converter
Old Sep 28, 2008 | 11:51 AM
pj7140's Avatar
TX Exhaust system glowing red-hot after replacing cat. converter
Hi, I have a 1991 Non-turbo convertible, 50 K. Car had been sitting for two years, ran perfectly up until last week. After completely restoring interior and exterior, went and put about 1/'4 tank of gas in it. drove home fine. next day went to start it- Catalytic converter shot (red hot) . Removed and replaced with a new Eastern CC (front and center). Now, it will start but cuts off after 5 mins..... the entire exhaust from the manifold down pipe to the mufflers -glowing red-hot?? Huge afterburn problem for sure. I have no idea???
Thanks, PJ
Old Oct 2, 2008 | 02:12 AM
RotaryRocket88's Avatar
Top Down, Boost Up
The new cat has to be severely restricting exhaust flow. Get it out, hollow out your old cat, and run the car with basically a straight pipe until you can figure out what the deal is with the replacement.
Old Oct 24, 2008 | 01:10 PM
pj7140's Avatar
re
Hi, did that, no help! pretty sure that a seal blew through manifold...did compression test and no compression on rear rotor. Now, just looking for a replacement engine. Thanks, PJ
Th0m4s
Feb 26, 2019 02:04 AM
82streetracer
Aug 23, 2015 09:28 AM
GrossPolluter
Aug 22, 2015 11:23 PM
