Methanol
Old Sep 27, 2008 | 10:50 PM
pmr eng's Avatar
Methanol
Hi,
Just wondering what spark plugs, EGT's and ignition timing do you recommend for a rotary engine running hi boost and methanol?
So far I have this as my starting point
EGT's 800ºC (1472ºF) to 850ºC (1562ºF)
Ignition Timing
35-40 degrees vaccum
30 degrees a 0 psi (gauge pressure)
25 degrees @ 15psi
18-20 degrees @ 30psi
ramping down to 10-12 degrees @ 45psi
and 7-8 degrees 50 and more psi.
Your input would be of great appreciation
Cheers!
Old Sep 28, 2008 | 08:06 PM
mad20b's Avatar
Good luck getting anywhere 800 deg EGT on meth! Timing looks a little (lot) advanced for my liking too.
I doubt you will get too many people giving you useful information on meth - most workshops etc dont give away too much! As for plugs, the norm seems to be R6725 - 115s but I think these are too cold... Also on meth, it seems to like it a lot richer than petrol - around lambda .7... I guess you just have to get it on the dyno & have a play!
Old Sep 29, 2008 | 09:29 PM
pmr eng's Avatar
Hi,
Thanks for the reply
I will be going with the Trust/Greddy Racing Plug Pro RE10 Spark Plug
What EGT's will I be getting?
The less timing = higher the EGT temps
I have noticed alot of piston guys running higher than 800 deg
Would something like this be more apparent?
25-30 deg vaccum
25 deg a 0 psi (gauge pressure)
12-15 deg @ 15psi
8-10 deg @ 30psi
4-6 deg @ 45psi
1-3 deg 50+ psi.
I'll be aiming for 5-5.5 AFR, stoich for meth is 6.4
Old Sep 29, 2008 | 10:05 PM
mad20b's Avatar
depends what the engine likes really. if it was as easy as just throwing some numbers at it we would all be running 6s! That timing does look a bit better though.
I prefer to use lambda as it is a true representation of what is happening. Lambda 1 is stoich, Lambda .9 is 10% richer than stoich, lambda .8 is 20% richer etc. 5:1 is Lambda .78. Way too lean in my books - but hey - try it & see, your motor might like it! .70 is 4.5:1 FYI.
Old Sep 30, 2008 | 08:23 PM
pmr eng's Avatar
thanks for the info
At least I have a point to start from
When I was at the summernats (car festival) dyno comp this year I noticed this car http://www.youtube.com/watch?v=9TCzt-Se-Wg
was running on methanol and they happen to have a probe in the exhaust. I never saw a AFR as smooth as this cars, perfectly flat on 5.5:1 AFR. I figured that would be a good AFR to aim for, the car did make almost 2000hp at the wheels.
I'll start off going a little richer 4.5:1 and go from there.
Old Oct 6, 2008 | 04:30 AM
pmr eng's Avatar
Anybody else have information they'd like to share....?
Shainiac
Jul 17, 2019 02:20 PM
Sammy Built
Haltech Forum
Sep 28, 2015 03:18 PM
