Heat does not work, why?
Old May 11, 2002 | 10:04 PM
93TTRX7's Avatar
thermostat maybe?
Old May 11, 2002 | 10:06 PM
R1Outcast's Avatar
I read on another post about this same problem that the heat only blows on your feet, not face, on FD's. Cool air comes out of all the vents but hot air only goes to the feet.
Maybe someone else can back me up on this one?
Old May 11, 2002 | 10:10 PM
R1Outcast's Avatar
Originally posted by OneKrazyGuy
That is the funniest thing I ever heard in my life!
Yeah, I see now. I made a funny.
Old May 11, 2002 | 10:47 PM
Zoomspeed's Avatar
The heat and a/c comes out of all of my vents.
I had this problem a while ago and it just went away. the next day. Never figured out waht was wrong.
Old May 11, 2002 | 11:01 PM
R1Outcast's Avatar
Here's the thread...
https://www.rx7club.com/forum/showth...threadid=52603
Old Nov 18, 2002 | 08:57 AM
jfandl's Avatar
Heater Feature or Flaw - no heat from vents
Ok, so I am not crazy, the air coming out of the vents is cool and the air on the floor is hot. This morning I tested it and found 85 degrees at the vents and 118 degrees on the floor vents. Damn, no wonder my hands are cold when it's cold out. So apparently it looks like it's a "feature" of the 3rd gen. but is there a way to FIX the issue?
Old Nov 18, 2002 | 09:54 AM
rotariesrule's Avatar
the heat blows out at your feet because heat rises and that is the most logical way to run a heater.
Old Nov 18, 2002 | 12:26 PM
2-Rotor's Avatar
Garaged
These cars are not practical for every day living and were not supposed to be. Its true my car same issue you have cool air from the dash vents and hot air from the floor or lower vents.
Old Nov 18, 2002 | 01:08 PM
dubulup's Avatar
development
The last two things considered in designing this car were comfort and practicality. -Jack Yama?*_?gama$
Heat in face puts driver to sleep. Driver alseep in car is bad.
Old Nov 18, 2002 | 01:17 PM
jfandl's Avatar
Talking Had to laugh
I had to laugh on that one that heat in face put drive to sleep...Driver asleep in car is bad
Ok, cold air on hands makes hands stiff on cold morning. Stiff hands not good for operating steering wheel.
I was thinking if the heat was too much on the face, I could even try during down the temp or the fan. Those Mazda engineers thought of everything didn't they?
Thanks for the comments, made me laugh!
Old Nov 18, 2002 | 01:43 PM
Rx7pimpin's Avatar
Don't comment unless you know what you are talking about. that is the problem with the forum, everyone thinks the know the answer so they chime in.
In the owners manual it explains that heat will only come from the front window defroster and the floor. The reason is one that has already been stated: heat in the face makes a driver sleepy.
Old Nov 18, 2002 | 03:16 PM
adam c's Avatar
Cheap Bastard
Sometimes the temperature controller dial will slip out of place and not turn the temp up, even though you have turned the dial. To check this, pull the dial off. Pull it straight off. When it is off, you will see a little square hole. Behind the hole, the plate has a square nub that fits into the hole. When the nub fits tightly in the hole, it keeps the plate from turning, and allows you to change the temperature. If the nub is loose, you will turn the plate when you turn the dial, and not change the temp. If it is loose, turn the dial so the nub fits in the hole, and tighten the nut snugly. Don't over tighten.
Adam
sherff
Feb 24, 2019 12:09 PM
befarrer
Aug 14, 2015 04:18 PM
04G35S
Aug 14, 2015 07:31 AM
