Koni+S-techs= High Ride Height?
Old Sep 24, 2008 | 02:57 PM
ArmenMAxx's Avatar
I just installed the rear koni yellow shocks on my FD (SET ON LOWEST BUTTOM PERCH SETTING) and Tein S-techs, and my car is sitting almost stock ride height maybe even higher! I re-used the buttom rubber that sits on the perch cup but i doubt it would cause a ride height difference. The shock mount bolt is tightened all the way down, and the springs are sitting in the right place.
I have driven around and allowed it to settle in also.
What could cause the back to sit so high?
Old Sep 24, 2008 | 03:29 PM
FC_DRFT's Avatar
ROTARY JIHAD!!
Thats probably because the stock springs were pretty worn,this is not unusual. If you want a lower ride i suggest getting coilovers.
Old Sep 24, 2008 | 03:42 PM
ArmenMAxx's Avatar
I had the s-techs before hand. The car is supossed to be VERY low with S-techs and konis on lowest perch.
Old Sep 24, 2008 | 04:39 PM
gracer7-rx7's Avatar
needs more track time
You probably installed the spring perch upside down on the Konis. It happens and it will increase the ride height. Ask me how I know.
Old Sep 25, 2008 | 01:46 AM
ArmenMAxx's Avatar
yup I just finished the whole thing and I realized I installed the rear perch cups upside down............ I also just realized I forgot to put the film on one of the shocks... Ill leave that be for now
BTW overall the koni feel is GREAT. Car is more responsive and grippy compared to R1 shocks. The rear is SLAMMED also. I may set it at the middle perch later on.
Old Sep 27, 2008 | 12:11 AM
Ktec's Avatar
Renesis
shoop da whoop
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
NeilTee
Sep 15, 2015 08:46 AM
Ernstudet22
Sep 14, 2015 09:19 PM
