2nd gear grinding
Old May 11, 2002 | 06:14 PM
ttb's Avatar
ttb
No Cup Holder Racing
2nd gear grinding
the shift into 2nd grinds unless i do it very slowly and carefully. the rest of the shifts are not super smooth but seems okay. i've heard about the 5th gear problem, but does anybody else have this problem. or is it just my tranny is going bad. would redline or something similar help? thanks.
Old May 11, 2002 | 06:24 PM
user 84205's Avatar
I think redline in the Tranny sucks. Now I had it in my car and always had a hard time shifting, yes it was the proper level, and then I put in OMEGA and smooth as hell....
Old May 11, 2002 | 06:50 PM
R Xplicit's Avatar
bad 2nd gear synchro would be my guess
Old May 11, 2002 | 06:52 PM
ttb's Avatar
ttb
i guess i'll get new fluids in a few weeks, hopefully it'll help.
Old May 11, 2002 | 09:24 PM
user 84205's Avatar
GOOD LUCK
Old May 12, 2002 | 03:18 AM
mightyslash's Avatar
Will Work for Ferrari
I'm using Redline and it seems ok.
Old May 12, 2002 | 03:28 AM
93TTRX7's Avatar
I'm using redline and my 2nd gear crunches and grinds. My 3rd gear has one very small crunch unless i quick shift it in there...all the other gears are fine...my 5th gear is superb. Except my reverse is sometimes hard to get into...but then again it's reverse
Old Jan 15, 2003 | 08:10 PM
ooo
i have the as conditon as 93TTRX7
my 2nd and reverse gear grinds~
so can change the transmission oil help?
Old Jan 16, 2003 | 02:55 PM
FDjunkie's Avatar
I've had a weak 2nd gear synchro since car was new. Up shift is the problem (down shift is great) and is better when warmed up and engine is at higher RPM's, like above 3K or so. Also, shifts easier since I changed gear oil to NEO synthetic.
Old Jan 16, 2003 | 03:16 PM
cruiser's Avatar
Same problem here - 2nd gear grinds if I don't do it slowly. Do these additives really help ? I don't think there's much to do againt a bad synchro.
MILOS7
Oct 9, 2015 02:19 AM
