Oil pressure sensor
Old Sep 22, 2008 | 12:17 PM
RotativoPR's Avatar
Question Oil pressure sensor
Sorry if the post exist. used the search dint find what i wanted to know.
So the question in hand is Oil Pressure Sensor.
1) Where is it at (location) pic if possible pls!
2) Normal pressure for the 13b to put out and where is the point to look out for problems ( to High / to Low )
3) Good aftermarket gauge for Oil pressure. ( with warning lights or accurate read )
car is a N/A s5 FC3s
Manny-
Old Sep 22, 2008 | 10:28 PM
Black Knight RX7 FC3S's Avatar
Turbo power, activate!
its under the oil filter.
atleast around 30psi at idle is norm, and at 3000rpm it should be atleast 60psi
Old Sep 23, 2008 | 07:13 AM
RotativoPR's Avatar
ty
will take a look at it! reason I asked was cuz my gauge stop working! After a friend helped me change the master & slave clutch cylinder.
Old Sep 23, 2008 | 04:33 PM
jmadams74's Avatar
?? Stock location is rear left (driver's) side of engine as I recall. Some aftermarket units are on the oil filter pedestal, but that is not stock.
Old Sep 24, 2008 | 03:11 AM
joshrulz's Avatar
the sensors can actually leak around crimped seal if they get old, i was hunting for oil leaks for ages until i changed that bugger
Microtech
30
Apr 23, 2016 06:37 PM
Snoopy FD
Dec 8, 2015 01:45 PM
FullFunctionEng
Full Function Engineering
Aug 25, 2015 08:17 PM
20B Forum
Aug 18, 2015 02:46 PM
