Headlight wiring pinouts, anyone got them
Anyone have a pinout for the headlight switch for a s4? im redoing all the wiring in my fc and so well, need pinouts
if not, ill just post them up once i do figure them out for the next person
THey dont seem to list the pins on the back side of the actual headlight switch, im re using the switch and enough wire to allow me to use the first plugs, then im doing it all myself
I have gotten everything but highbeams and the turn signals figured out, wasnt as bad as i thought
-Jacob
-Jacob
Hmm. On the attached jpg of the circuit, they show 9 wires coming out of the switch. Then if you look at the second jpg, of the plug that attaches to the light switch, there are how many wires????? Oops, the answer is 12.
So what do those three wires do in life that are not shown on the dwg??? Got me. I looked for a while and got tired of looking. I bet my 87wiring shows them. But it's not clear on this 88 dwg. I might look later.
The B/G, B/L and some other wire(edit: B/R) in the plug are not shown in the dwg. I think I looked, and the B/G goes nowhere. You might double check that.
Well my manual didnt give inputs for the actual plug, or color's of the wires even, just enough to figure out how it all worked
thanks
-Jacob
thanks
-Jacob
The1Sun
Sep 15, 2015 04:45 PM
windom
Sep 11, 2015 04:48 AM
The1Sun
Sep 7, 2015 10:21 PM
