Haltech e6x sensor pack?
Old Sep 19, 2008 | 12:01 AM
boost_its_what_for_dinner's Avatar
RotoriousRx7
e6x sensor pack?
so is there a sensor pack that you dont have to tap the holes bigger to make them work?
need to know asap thx
Old Sep 19, 2008 | 08:24 AM
C. Ludwig's Avatar
www.lms-efi.com
There is a direct replacement coolant temp sensor. You will need to drill and tap a hole for the air temp sensor. Since your car is an S4 you will need to fabricate a mount for the Haltech TPS sensor or convert to an S5 throttle body/S5 TPS sensor. Does that answer your question?
Old Sep 19, 2008 | 09:41 AM
gxl90rx7's Avatar
destroy, rebuild, repeat
you can use the stock coolant temp sensor, its only 10 degrees off
Old Sep 20, 2008 | 12:19 AM
RotoriousRx7
i heard about that but can you just get a s5 tps or do you need the tb too?
and 90gxl can you calibrate the readings to read correct?
Old Sep 20, 2008 | 06:18 AM
C. Ludwig's Avatar
www.lms-efi.com
You need the throttle body too. The S4 TB does not have the proper cam to run the S5 TPS. Yes, they work just fine.
