gear ratios....
Old May 11, 2002 | 11:11 AM
sinfestboy's Avatar
gear ratios....
does anyone have the gear ratios for a stock 93/94 FD?
Old May 11, 2002 | 01:06 PM
twinturborx7pete's Avatar
Juris Doctor
ya i was wondering that too.. because i'm interested in the 4.33 gears from SRX7.com
Old May 11, 2002 | 01:34 PM
ttb's Avatar
ttb
No Cup Holder Racing
i ran across this the other day
http://www.marx7.org/infocenter/faqs/3rd_faq_2.html
Gear Ratios: Manual Automatic
1st gear 3.483 3.027
2nd gear 2.015 1.619
3rd gear 1.391 1.000
4th gear 1.000 0.694
5th gear 0.719 ----
Rear end 4.100 3.909
Old May 11, 2002 | 05:38 PM
sinfestboy's Avatar
thank you ver much
Old May 11, 2002 | 05:49 PM
sinfestboy's Avatar
ok, I compared it to some other stuff.... would I be able to only change 1st gear? Its REALLY short, and one a bit taller would make me happ.... maby 2.8-3.0....
Old May 11, 2002 | 06:02 PM
user 84205's Avatar
ALSO Im going to tell you right off. You guys I was told by many car companies here you dont need a sensor, I heard there was some confusion on those. GOOD LUCK
You only need the sensor if you drop to 3 or go to 4.77
Old May 11, 2002 | 06:08 PM
sinfestboy's Avatar
what?
Old May 11, 2002 | 06:09 PM
user 84205's Avatar
in other threads they discussed, weither you need a new sensor due to changing the rear-end gears.
Old May 12, 2002 | 08:22 AM
sinfestboy's Avatar
o, ok...... well, can you put in a new first gear? if yes, what gears can you buy individually?
Old May 12, 2002 | 02:57 PM
sinfestboy's Avatar
anyone?
MILOS7
Oct 9, 2015 02:19 AM
musker
Oct 1, 2015 05:58 PM
