S5 TII short block going in S4 NA
ok, i read up on some procedures in doing this and supposely the point of all this is too make the ECU still think the engine is a S4(while its a S5).
i got the intake/exhaust manifolds and TB... TII fuel rails, ECU, AFM
what else do i need?
i know i need a TII tranny and upgrade the fuel pump... what about the driveshaft? any changes in that? or should i get a custom made one? well... i was thinking if i needed one, i'd get it from this place... http://www.pstds.com/
well, after all that, would everything be plug and play.
If you are keeping your n/a diff and using a TII trans you need a custom driveshaft. You can get it at mazdatrix.
You don't need a tII tranny but you would be wise to use one, with a TII Tranny you also need - TII Clutch Slave Cylinder, TII Clutch and PP, TII Flywheel
