What cap do I use with evans NPG?
Old May 11, 2002 | 12:18 AM
Zoomspeed's Avatar
What cap do I use with the the evans NPG?
Wouldn't just removing the rubber ring part of a regulr pressure cap just cause a leak?
I'v already switched out my AST with one of pettits ASTs/
Old May 11, 2002 | 01:53 AM
GsrSol's Avatar
Z06 powered FD
Any cap will work. Do NOT remove the rubber gasket, it makes a seal and will cause it to leak, not build pressure.
Old May 11, 2002 | 03:22 PM
Zoomspeed's Avatar
So I'm suppose to use regulalr pressure cap with NPG? Isn't the NPG suppose to use a 0 pressure cap?
Anyone know where to find one?
Old May 11, 2002 | 03:27 PM
Bacon's Avatar
IRS 4 Life
use the one that came off the stock thermo neck...its 0 psi..or if you only have the one after you elinated the ast cut the rubber seal off the bottom part of the cap(the part at the bottom) not the gasket around the top of the cap
Old May 11, 2002 | 03:57 PM
Zoomspeed's Avatar
I dont' have any spare caps, so could I just buy one and take off the seal?
Old May 12, 2002 | 01:19 AM
Bacon's Avatar
IRS 4 Life
yea....will work fine
Old May 12, 2002 | 02:24 AM
user 84205's Avatar
MAZDA, they are good for one thing, stock parts.....
Jetlag
Sep 29, 2015 06:52 AM
GKW
Sep 28, 2015 04:34 PM
