Clutch Question
Old Sep 12, 2008 | 07:03 PM
bcbjj's Avatar
Clutch Question
So my question is this.. If the S4 and S5 transmissions are interchangeable how do I determine between getting an S4 or S5 clutch kit? If they are swappable does it matter which I use? Do I need the kit to match the trans or the engine and if the trans how do I determine which trans I have? Thanks for any help
Old Sep 12, 2008 | 07:31 PM
dawicka2's Avatar
well rested,buffet o food
flywheel counterweight should match engine(s4 or s5) pressureplate and disk should match trans type (na t2)
john ny
Old Sep 12, 2008 | 07:39 PM
bcbjj's Avatar
ok got ya, but when choosing a clutch kit from RX7 world or Mazdatrix it gives me the option of 86-88 non turbo or 89-91 non turbo.
What's the difference?
Old Sep 12, 2008 | 08:02 PM
ITSWILL's Avatar
Wiring Nightmare
well lets see ,
Your car is a 1990 NA
therefore you would want the one for your year so get the one that says 89-91 non-turbo.
Old Sep 12, 2008 | 08:03 PM
ITSWILL's Avatar
Wiring Nightmare
s4=86-88
s5=89-91
Old Sep 12, 2008 | 09:06 PM
bcbjj's Avatar
hehe, yes I understand what model my car is.... the question is if I am using an S4 transmission on an S5 do I still use the S5 clutch kit or would it need to match the S4 trans
Old Sep 12, 2008 | 09:26 PM
ITSWILL's Avatar
Wiring Nightmare
I honestly don't know.
It sounded like you didn't know what tranny you had in your car. Some people are simple and you just have to give it to them on their terms. LOL
If it were me I would give mazdatrix a call monday morning.
Old Sep 12, 2008 | 09:31 PM
fcforlife's Avatar
rotary tech
you should use the clutch kit to match the engine its a common miss conception. im sure there is probably no difference in the two kits. however the s5 engine did produce more hp. so i would get the s5 clutch kit because they may have made the pressure plate heavier for that reason. but in the end they will probably both fit on and both work.
Old Sep 13, 2008 | 05:30 AM
Turbonut's Avatar
Go with a S5 kit as the throwout bearing and fork differs from a S4, at least from the factory. Actually the factory disc and pp are also different from the factory, but aftermarket carries the same designation for both S4 & S5.
Clutch Fork
84-88 N/T 16-5200-N204
89-92 N/T 16-5200-N302
Release Bearing
83-88 16-5100-FE84
89-92 16-510C-G561
Old Sep 13, 2008 | 07:49 AM
bcbjj's Avatar
ok great, thanks guys
alphawolff
Nov 17, 2015 05:57 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
