What is this little black box?
Old Sep 9, 2008 | 01:06 AM
Ex-Eg-Driver's Avatar
RX-7 DISCIPLE
What is this little black box attached to the Slave Cylinder Bolt?
What is its function?
Old Sep 9, 2008 | 06:30 AM
clokker's Avatar
Cake or Death?
It's a condenser that's connected (well, supposed to be) to the oil pressure gauge circuit.
It dampens the signal to the gauge so the needle isn't jumping all over the place.
Old Sep 9, 2008 | 11:38 AM
89GXLer's Avatar
According the my '89 Mazda service manual, it's supposed to be on the bolt that holds the little steel cover over the hole between the motor and the trans.
I know this because when I got my car it wasn't attached and when I put my engine back in after rebuilding it, I looked all through the manual to try and find a diagram showing it until I found it.
One thing to note is I believe there's a plastic connector not too far along the wire that you can disconnect. Take a look around to see if that's hanging anywhere to find the wire.
Grant
Old Sep 9, 2008 | 12:06 PM
87 t-66's Avatar
not a drifter
wow...just wow...
from the FAQ:
What is this little black box with a single wire and a small metal tab that is mounted near or on the clutch slave cylinder?
It is the Condenser (capacitor) for the Oil Pressure Sender. It is needed to protect the oil pressure gauge from burning out in the event of sender failure, and for smoothing any erratic pluses from the sender.
clokker is the winnar!
Old Sep 9, 2008 | 05:26 PM
RX-7 DISCIPLE
Thanks again guys....
Seems mine is broken.
Old Sep 9, 2008 | 05:49 PM
clokker's Avatar
Cake or Death?
Originally Posted by 87 t-66
wow...just wow...
I'll take door number three, Monte!
Old Sep 9, 2008 | 06:54 PM
HAILERS's Avatar
HAILERS
And behind doooooooor nuuuuuuuummmmmmmbbbber threee, is....................................a 1985 Yugo!
Old Sep 9, 2008 | 08:17 PM
clokker's Avatar
Cake or Death?
YAY!
Better gas mileage!
dludden
Aug 26, 2015 11:25 AM
