Synapse Wastegate
Old Sep 5, 2008 | 06:32 PM
sk8world's Avatar
Chasing numbers
Synapse Wastegate
Anyone running one and have the tested hook up with a boost controller? I amm used to running it inline were as this on just has one line going in to it. I would think you would run a line to boost controller on "IN" then "OUT" to gate????
Old Sep 5, 2008 | 06:38 PM
I run the WG, but don't quite understand what you just wrote as far as setup.
Old Sep 8, 2008 | 12:27 PM
sk8world's Avatar
Chasing numbers
So how do you have yours run? Are you running a boost controller?
Head cold still, nothing I say makes any sense the last few days... lol....
Old Sep 8, 2008 | 06:24 PM
Yes I'm running a boost controller, SARD unit.
Port A and B are controlled by the EBC and Port C see's a direct boost source.
What psi are you planning on running and what turbo setup do you have?
Old Sep 8, 2008 | 07:00 PM
sk8world's Avatar
Chasing numbers
Boost will be upper 20's depending on the tuning out come. Turbo is a 4094r.
The above makes some sense, I just did not see in the owners manual were differant boost/vac sources went to what ports.
Old Sep 8, 2008 | 07:30 PM
If you want upper 20's you will need both main and pre-load 60 lbs/in springs. Depending on back pressure and responsiveness you may need to go to the smaller valve opening piece and add a few turns of pre load. You will also most likely have to have the boost only source on port D instead of C. Go slow and in stages, the level of control with the Synapse WG is awesome, but you really need to fully understand it to get the full benefits of the design. Doing everything all at once will result in over boosting if your going into it blindly.
Old Sep 8, 2008 | 08:42 PM
kwerks's Avatar
Racing Spirit
i use one and I use its boost controlling feature works well and holds super solid levels
Old Sep 9, 2008 | 12:07 AM
sk8world's Avatar
Chasing numbers
ok, thanks for the info. I am not going to begin running any boost until I get this new motor/issues worked out. Just trying to have the info I need when the time comes.. Thanks again..
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
