Megasquirt Megalogviewer not so accurate RPM vs. VE bins views
Old Aug 30, 2008 | 03:29 PM
mperformance's Avatar
Im having a little trouble viewing the tuning VEBins1 based on the RPM values reported on the actual graph.
is there a bug in the software that you are all aware off?
basically if I see a 5000rpm in the ticker in the graph the dots in the VEbins and advTable1 are way of like in 8000rpm range.
its like 3000rpms off. at 900 rpm it shows the dots at the 3500rpm cells.
any ideas on how to solve that?
Old Aug 30, 2008 | 03:32 PM
BTW car is running great. I just got the car reviewed by a local webpage. We did a couple of highway passes and its running nice with the squirt feeding the 1600cc injectors. This is truly a sweet daily driver now.
Old Aug 31, 2008 | 07:56 PM
muythaibxr's Avatar
MegaSquirt Mod
I didn't know of any bugs but if you post on msextra.com to the megalogviewer site, I'm sure Phil will fix anything he finds.
Ken
Old Sep 1, 2008 | 09:25 PM
ok the problem was simple to fix. I was not loading the log file in megasquirt with the same MSQ used. Now everything reads fine.
Its important to transform the log file from the palmtune using the exact MSQ file. duh. anyhow got it working.
Anybody has some tuning parameters to share? I got an 11.8AFR at 6krpm under load at 11psi, thats a 3rd gear pass on the highway.
Old Sep 1, 2008 | 09:31 PM
here is a picture of my log now fixed. Feel free to comment. Attached my MSQ Fuelbins and ignition...
550cc x2
1600cc x2
streetported 13b S4 block
rgordon1979
40
Mar 15, 2022 12:04 PM
Ian_D
Oct 14, 2015 12:31 PM
